View Poll Results: What PSI are you running in your OEM or Aftermarket Tires?
30-35PSI
21
48.84%
35-38PSI
19
44.19%
38-41PSI
4.65%
41-44PSI
4.65%
44-47PSI
0%
47+ (specify)
0%
Multiple Choice Poll. Voters: 43. You may not vote on this poll
What tire preassure are you running?
Old Dec 27, 2003 | 07:17 PM
jeffrey's Avatar
jeffrey
Question What tire preassure are you running?
Just curious what you guys are running.
Old Dec 27, 2003 | 09:13 PM
Silver Bullit II's Avatar
Silver Bullit II
f = 35
r = 34
JMS in TX
Old Dec 28, 2003 | 12:28 AM
Beaker02's Avatar
Beaker02
I run @ 34 cold. I've seen them warm to 40 on rare ocation. Does keep the alarm off in really cold weather.
Old Dec 28, 2003 | 03:41 AM
teh215's Avatar
teh215
This time of year it is hard to get the pressure right since it is 25° in the morning and up to 55° in the afternoon but I usually try to keep it around 35 in all 4 tires.
Old Dec 29, 2003 | 01:51 AM
D'oh's Avatar
D'oh
I chose 35-38.
I try to keep it @ 35 cold in the mornings. I'd rather run a bit high than a bit low, since higher pressure can improve fuel economy, reduce wear, and reduce the rollover of the front tires is hard corners. When racing, I try to keep the pressures below 42 hot.
-D'oh!
Old Dec 29, 2003 | 08:37 PM
SHO-TIME's Avatar
SHO-TIME
36 cold at all 4 corners.
(OEM Touring 18 inchers w/ SO3's)
Old Dec 29, 2003 | 09:26 PM
ares's Avatar
ares
Veteran
just did my tires tonight; used a digital gauge and got them all at 35psi at about 50degrees.
theyll drop from there and when the alarm goes off Ill take note to refill them to 35 again.
Old Dec 30, 2003 | 04:07 AM
John's Avatar
John
If you keep the tires around 35-36 cold, once they heat up, they'll be around 37-38 (or higher). On my original tires, I had this setup, and after about 13K, the rears had worn to the tread bars in the center, thus indicating that the tires were overinflated. I have since lowered it down to about 33 cold.
Old Dec 30, 2003 | 01:23 PM
350ed's Avatar
350ed
Professional
With aftermarket rims/tires, do you go with the Nissan recommended 35 or go with the tire (50psi max?)
Thanks.
Old Dec 30, 2003 | 01:33 PM
jeffrey's Avatar
jeffrey
I run mine a little higher than normal, but I'm not running factory tires/wheels either. I'm running 245/35/20 front, 275/30/20 rear. I'm currently running 44psi cold (they are 50psi max).
Old Jan 2, 2004 | 11:16 AM
kwadell's Avatar
kwadell
I keep my tires at 32 psi minimum. Usually 32-34 psi.
Old Jan 2, 2004 | 11:44 AM
jor8888's Avatar
jor8888
36 f for less tire feathering.
32 r for better grip.
Old Jan 2, 2004 | 11:45 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
front- 40psi
rear-35psi
