buying wheels, HELP!
Old Nov 19, 2012 | 05:57 PM
cookies4christy's Avatar
cookies4christy
Default buying wheels, HELP!
SO, I have my eyes set on these wheels that are :
work vz-xx
bolt pattern 5x112 pretty sure the centerbore is 57.1
19x11 +2
19x10.5 +15 (I have a 10mm spacer to clear my bbk)
Falken fk452 235/35 front and 265/30 rear.
he has an audi,
I have a 2004 track model 350z with brembo brakes.
I saw another thread saying that these wheels would NOT fit on the car
Will i be able to fit this in my car without scraping?
and what do i need in order to achieve flush fitment?
spacers/ camber kit/etc?
thanks in advance guys
Old Nov 19, 2012 | 06:05 PM
terrasmak's Avatar
Lots of fun trying to bolt them on
Old Nov 19, 2012 | 06:06 PM
RyebreadZ's Avatar
RyebreadZ
Are you going to use adapters because that's not the right bolt pattern for a Z....
Old Nov 19, 2012 | 06:09 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Those specs are pretty aggressive, what were they on, an RS4?
Specs seem pretty aggressive. If you haven't done fender work then I would recommend doing so. Also, if the wheels are in 5x112 with a bore of 57.1mm you will need to both redrill the faces to 5x114.3 as well as bore the center bore larger.
Old Nov 19, 2012 | 06:27 PM
Phenom's Avatar
Phenom
Toasty
More trouble than what they're worth. Pass.
Old Nov 19, 2012 | 06:37 PM
kingdom's Avatar
kingdom
Ive thought about doing funny wheel swaps, like porsche rims.
I assume youve seen this thread??
https://my350z.com/forum/wheels-and-...er-thread.html
should have most the info you need about offsets. gl
Old Nov 19, 2012 | 06:42 PM
Nismo350z#0310's Avatar
Nismo350z#0310
OP, not only is the bolt pattern wrong, but this is the type of camber you'd need to fit those wheels under the fenders.
http://youtu.be/zhT3C9mHLZ4
Old Nov 19, 2012 | 11:25 PM
alexasthoma's Avatar
alexasthoma
Old Nov 20, 2012 | 12:53 AM
bluelineshooter's Avatar
bluelineshooter
Old Nov 20, 2012 | 08:29 AM
VMRWheels's Avatar
VMRWheels
I would agree. Not to mention that wheels in the correct bolt pattern, center bore, and sizing are dime a dozen.
Old Nov 21, 2012 | 06:35 PM
cookies4christy
lolll,
hahaha yeah not worth the trouble.
will just have to find different wheels
thanks everyone (:
