Toyo TS1 Uneven wear...big time
Old Jan 19, 2004 | 05:12 PM
bigdaddy's Avatar
bigdaddy
Default Toyo TS1 Uneven wear...big time
well, i just had to switch my toyo's side to side because of grossly uneven wear on the inside shoulder. every bit of tread depth was gone on the inside inch or two. i have put about 7500 miles on these bad boys, and have loved them the whole time. i hadn't even noticed the uneven wear until it was pointed out to me. i have run one autocross and one HPDE on them. i keep them at 35 psi while on the road.
the problem is, i almost ruined a pair of very expensive tires in 7500 miles. so..my question: has anyone else out there had any problems with their toyo's doing this same thing? i was really hoping the stock tires were part of the uneven wear problem. obviously not. granted, i do have aftermarket wheels as well, which may make some difference. i have done the alignment thing, and hopefully that will help. otherwise, i guess i have to plan on getting cheaper tires from now on.
sean
Old Jan 19, 2004 | 05:45 PM
westpak's Avatar
westpak
SFZCC
Did you do the alignment thing before you put on the Toyo's? If not that is the reason for the wear not the Toyo's.
I put on Toyo's after the alignment and no problems ina year.
Old Jan 19, 2004 | 06:15 PM
Jeff@Evolution's Avatar
Jeff@Evolution
How low is your car lowered? And did you ever check for Camber on your car?
Old Jan 19, 2004 | 07:04 PM
westpak's Avatar
westpak
SFZCC
No sure who you were asking but mine is lowered with Eibachs or around 3/4 of an inch, I had it checked after and front Camber was at max -1.3
Old Jan 19, 2004 | 07:36 PM
apex locator's Avatar
apex locator
my toyo t1s are fine also. i have nismo s-tunes....2 track days on them.
Old Jan 19, 2004 | 07:55 PM
350ed's Avatar
350ed
Professional
Is it just the front or also rear? Maybe look into a front camber mod since it's cheaper than half lifeing those tires!
Old Jan 19, 2004 | 08:08 PM
FLY BY Z's Avatar
FLY BY Z
www.kinetixracing.com
Old Jan 20, 2004 | 05:19 PM
bigdaddy's Avatar
bigdaddy
i did do the alignment...after i noticed the problem. hopefully that will remedy it.
the car is not lowered in any way. i will look into some front camber adjustments if it comes back. i'll just cross my fingers in the meantime.
sean
Old Jan 20, 2004 | 06:13 PM
KCZ's Avatar
KCZ
I had an alignment done before I put my T1S's on, then ran them for 9000 miles and 12-15 autocrosses with only the normal, expected wear.
Then after 4 consecutive track days, which left them badly chunked (they weren't designed for that kind of abuse), I pulled them off to find that the right rear tire was worn down to the cord on the inside edge. I also found that the camber on that side was -5 (!!!) compared to -2 on the left side, which was undoubtedly the cause of the wear pattern. I suggest you have your alignment rechecked.
After installing adjustable rear camber arms, I replaced the tires with Potenza Pole Positions, only because the Bridgestone dealer is a lot closer than the Toyo dealer. These tires totally suck--they're no better than the stock Potenzas and there's a huge difference in the way the car handles on the street compared to the Toyos. I'd give anything to have another set of T1S's instead of these things.
Old Jan 20, 2004 | 06:54 PM
alex30327's Avatar
alex30327
10K+ miles on my Toyo TS1's and going strong. Going to rotate the front tires soon just to be safe.
Old Jan 20, 2004 | 11:46 PM
ZISBAK's Avatar
ZISBAK
So, are we supposed to have it alignment done with the stock tires, and then put the aftermarket wheels and tires on? I'm planning to put some 19's on in about 2 months from now, but currently i'm running stock wheels with the lower profile than the stock tires on. (225/40/17 and 245/40/17), I would think you put the aftermarket wheels and tires on, then get the alignement to match what you have? my car also has an .5 inches drop.
Old Jan 21, 2004 | 04:08 AM
westpak's Avatar
westpak
SFZCC
I wouldn't worry about it unless you are having wear now.
I assume the drop you are mentioning is from the lower profile tires, if that is the case it should not affect it since that just sits the car lower evenly while springs lower your actual suspension changing the geometry of it.
Old Jan 21, 2004 | 05:56 AM
ZISBAK's Avatar
ZISBAK
Actually it would about close to 1 inch drop, that included the lower profile, and also progressive spring (10mm drop). So, should I get a alignment now to get back within the spec, and then don't worry about it when I change out the new wheels and tires?
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
