Worst-ever case of feathering on a 350Z
Old May 14, 2013 | 01:55 PM
winchman's Avatar
winchman
Default Worst-ever case of feathering on a 350Z
Notice the flat areas visible around the upper part of the tire.
Attached Thumbnails Worst-ever case of feathering on a 350Z-2013-05-14_1752_tire_wear.png
Old May 14, 2013 | 02:06 PM
terrasmak's Avatar
Looks like cupping
Old May 14, 2013 | 02:32 PM
sk8r776's Avatar
sk8r776
That's definitely cupping. I cant really read the model. Kinda looks like potenza's. Maybe suspension issue?
http://www.ehow.com/about_5509983_ca...ing-tires.html
Old May 14, 2013 | 02:44 PM
flynzed's Avatar
flynzed
Looks like the wheel / tire was out of balance.
Old May 15, 2013 | 10:19 AM
Z33Garage's Avatar
Z33Garage
Deff cupping. Either out of balance/ not rotated or maybe you had bad bushings or suspension.
Old May 15, 2013 | 12:28 PM
dcains's Avatar
dcains
+1 to all the above comments. There have got to be some sloppy parts in that front end, whether bushings, bearings, or bad shocks, I can't say, but take it to a shop and get a proper check done. This isn't a simple alignment issue. Driving with a tire like that is not only dangerous, but it's also beating the hell out of the rest of the front end.
Old May 19, 2013 | 09:52 AM
B-Mackin's Avatar
B-Mackin
fix those hockey puck sized bushings!
Old May 19, 2013 | 09:33 PM
ronn1's Avatar
ronn1
If one wheel only>>.Cupping>>Bad shock #1 cause
Both>>feathering>>>toe out
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
