PSA: When asking "will this rub"....
Old Sep 17, 2015 | 04:38 PM
  #221
davidm350's Avatar
davidm350
Originally Posted by davidm350
Will this rub?
19x10.5 +22 F&R
255/35/19 F
285/35/19 R
My 2007 Z sits on Megan lowering springs (from previous owner) which is a 2" drop. I don't know the camber spec.
Fenders are not rolled.
Can anyone help me?
Old Sep 17, 2015 | 04:40 PM
  #222
PP08HR's Avatar
PP08HR
most def be rubbin'
Old Nov 3, 2015 | 05:22 AM
  #223
BigBoss8's Avatar
BigBoss8
What offset do you guys suggest the most on the rear:
18 x 9.5 +15
Or
18 x 9.5 + 30
I'm debating on the Enkei TSP6 or Enkei Kojin.
OR
Enkei PF01 in
F18x8.5 +30
R18x9.5 +35
The offset is just what throws me off. I have used calculators to check clearance, but I don't know if +15 Or +30 in the rear would look/be best.
Thanks
Old Nov 3, 2015 | 05:23 AM
  #224
travlee's Avatar
travlee
Master
+15 front and rear
Old Nov 3, 2015 | 05:36 AM
  #225
BigBoss8's Avatar
BigBoss8
Originally Posted by travlee
+15 front and rear
The PF01 only has:
F +30, +35
R +15, +30
TSP6:
F +25
R +15, +30
Kojin:
F +25
R +15, +30
The tires have to come off tire rack. Family friend runs a tire shop and is going to get them to me for cost as he doesn't stock Enkei.
The offsets are all offsets available in the rim widths I am after (previously mentioned)
Old Nov 3, 2015 | 05:44 AM
  #226
Gunkata's Avatar
Gunkata
You can order a set of 4 "rears" at +15:
I am running a square set of 245s all around, which is stretched slightly, but these are just A/S tires and usage for winter right now, as my Star Specs extreme summers are on the stock oem track wheels for now. Once those are burned out, I will most likely move the A/S to them and then look to go 265 all around on these Enkei's. that said, it will require front control arms and a new alignment to get more negative camber up front. You could also run +25 up front and +15 in the rear, and not worry about it at all, but I was going for a completely square setup for rotating down the line, more so for the track tires. but if just street/DD, I'd say best is their +25 F and +15 R recommendation/setup.
Old Nov 3, 2015 | 05:53 AM
  #227
travlee's Avatar
travlee
Master
this
Old Nov 3, 2015 | 06:06 AM
  #228
Gunkata's Avatar
Gunkata
this
^ indeed, plus, you get the concave faces all around
Old Nov 8, 2015 | 09:24 AM
  #229
davidsk8er7's Avatar
davidsk8er7
Default Will I run with these wheels?
Hey guys I've been searching the web/forums to see if anyone was running the same set up I'm about to run but haven't had much luck.
I have a '03 Z enthusiast, lowered on top speed adjustable coilovers, fenders rolled. I previously had a 18x10.5et22 squared set up wrapped with 235/40 all around
Trying to do something different this time. I'm about to purchase some wheels with basically new tires on them from a private seller this week.
Specs are 19x9.5et0 19x10.5et0 wrapped in 245/35 and 265/35
So my question is, being lowered will these wheels fit without rubbing?
Old Nov 8, 2015 | 09:27 AM
  #230
davidsk8er7
Here's a picture of my ride hight on the 17" OEM's
Attached Thumbnails PSA: When asking "will this rub"....-image.jpeg
Old Nov 13, 2015 | 11:39 AM
  #231
Mercutilis's Avatar
Mercutilis
Hey Guys;
Got an '04 Performance that's currently running 245/35ZR18 , 275/35ZR18 on stock rims and stock suspension from what I can tell there is no stretching or bulging. My question is this, my local tire shop has discontinued the tires I'm using and the closest I can get 245/40ZR18 , 275/40ZR18 to replace them. Am I going to have an issue with rubbing or just when I go into corners. Dealership was no help.
Thank-you in advance
Old Nov 13, 2015 | 03:49 PM
  #232
terrasmak's Avatar
Originally Posted by Mercutilis
Hey Guys;
Well the tires you found are the proper size for the car, just not for your wheels. Until you get a proper width wheel, 245/40-18 front and 245/45-18 rear is a much better choice
Old Nov 13, 2015 | 08:46 PM
  #233
Mercutilis's Avatar
Mercutilis
Thumbs up
Could you pls elaborate on this suggestion? Why is it better/preferred and how it would affect ride/suspension.
Thanks
Old Nov 14, 2015 | 10:16 AM
  #234
terrasmak's Avatar
Thanks
Tires are the same height as stock , just wide. Keeps your gearing like OEM and of course looks better ( properly filling the wheel well)
A 275 needs a minimum of 9 inch wide wheel for proper handling, 10 is actually prefured , you have 8 inch wide wheels. A 255 needs an 8.5 inch wide wheel , 9 is better, and you only have an 8 inch wide front wheel.
Old Nov 25, 2015 | 09:33 AM
  #235
PiPPiNiZED's Avatar
PiPPiNiZED
2008 stock 350z and hoping to mount a square set up with the rims/tires
Rims- 18 x 9.5" with 40mm offset (Probably TSW Nurburgring irms)
Tires- 245/45 r18 (Probably Bridgestone G-force Sportcomp 2)
I currently have 20mm spacers on the rear axle.
I'll be reading this whole thread to see if anyone has a similar set up, as well as learning the whole offsets thing. Coming from a bike background, so offsets are fairly new to calculate.
Old Nov 25, 2015 | 01:31 PM
  #236
Gunkata's Avatar
Gunkata
Rears will be good, but fronts should have same spacers too, as 40 is very high, higher than stock by like 7-8mm, iirc.
Old Nov 25, 2015 | 02:24 PM
  #237
terrasmak's Avatar
If you haven't bought the wheels yet, don't. Look for something with better specs
Old Nov 25, 2015 | 07:33 PM
  #238
MicVelo's Avatar
350Z/370Z Tech Moderator
^^^^ What Terrasmak and Gunkata said.
40mm is about what a 370Z uses. Z33 run 30mm offsets as stock.
And just word to the wise, think you're confusing the G-Force tires.... which are made by Goodrich. But no worries, I know what you meant. Heh heh.
Offset: See THIS LINK.
Old Nov 26, 2015 | 05:41 AM
  #239
PiPPiNiZED's Avatar
PiPPiNiZED
Many thanks, guys. One can only google soo many websites before info gets crossed
Old Nov 28, 2015 | 06:14 AM
  #240
neilca's Avatar
neilca
Default Miro 111's on a ZR Grand Touring
First the car,
2008 Grand Touring Roadster, stock, no lowering, or shocks, all stock.
I bought 4-8.5X18 +30 offset Miro 111's. I want to run 235x45x18 tires all around. I am willing to use the stock 225x45x18 front and 245x45x18 rears if I have to.
My problem is with the front Brembos. They do not clear the wheel. The rears are fine. I need to use a 1/2 inch spacer to clear the caliper. I am afraid this is going to drive the wheel too far outboard. I think it will work using the 225 tire.
What does the board think, will it rub?
