PSA: When asking "will this rub"....
Old Nov 28, 2015 | 07:37 AM
  #241
terrasmak's Avatar
Originally Posted by neilca
First the car,
2008 Grand Touring Roadster, stock, no lowering, or shocks, all stock.
I bought 4-8.5X18 +30 offset Miro 111's. I want to run 235x45x18 tires all around. I am willing to use the stock 225x45x18 front and 245x45x18 rears if I have to.
My problem is with the front Brembos. They do not clear the wheel. The rears are fine. I need to use a 1/2 inch spacer to clear the caliper. I am afraid this is going to drive the wheel too far outboard. I think it will work using the 225 tire.
What does the board think, will it rub?
I would do equal spacers front and rear, you will have no problem running 20mm at all.
Best thing to do, return the wheels , use the $200 you would need to spend on spacers and buy something better.
Old Nov 28, 2015 | 07:57 AM
  #242
neilca's Avatar
neilca
I would do that, but I like the way the wheels look. Can you recommend another wheel that looks like these?
Thanks,
Old Nov 28, 2015 | 10:04 AM
  #243
Gunkata's Avatar
Gunkata
www.tirerack.com should have some options, I'd imagine. Sites like that are great because they can tell you right off the bat if they clear your calipers, etc. But still sell some with "bad" offsets, lol.
Old Dec 13, 2015 | 08:14 PM
  #244
05redzed's Avatar
05redzed
Default Varrstoen es2 on 05 roadster
Wanting to buy 19x9.5 +12mm and 19x10.5 0 mm varrstoen es2 don't know what size tires yet willing to stretch a bit. Stock ride height . Will it rub ? If it will. Would a +12mm in the rear fix this ?
Old Dec 14, 2015 | 05:30 AM
  #245
VenomGT9's Avatar
VenomGT9
Go with the +12.
255/35 and 285/35
Old Dec 18, 2015 | 07:45 PM
  #246
More Lotion's Avatar
More Lotion
About to pull the trigger on a set of ES6.
I'm thinking on going 19x9.5 +22 fronts and 19x11 +25 in the rears.
Offset Options: front: 0+ 22+ +12 | rear: 0+ 25+ +12
Tires: f:255/35/19 - r:285/35/19
I also have a stock height Z and would like a setup without rolling and having no rubbing. What do you guys think on the offset and tire choice? Appreciate the feedback!
Old Dec 18, 2015 | 08:07 PM
  #247
terrasmak's Avatar
Front will be fine, the rear will be close. It's best to roll the rear
Old Dec 18, 2015 | 10:03 PM
  #248
Zmasterflex's Avatar
Zmasterflex
Default Will this fit?
Zedd sl5 wheels
18x9.5 +12 245/40r18
18x10.5 +15. 275/40r18
Rolled fenders
Bc racing coilovers
Old Dec 18, 2015 | 11:04 PM
  #249
terrasmak's Avatar
Originally Posted by Zmasterflex
Zedd sl5 wheels
Rolled fenders
Bc racing coilovers
Without issues
Old Dec 19, 2015 | 12:57 AM
  #250
More Lotion
Thank you for the quick respond Terrasmak!
If you don't mind.
What do you think about this instead:
For: 19x9.5 +22 fronts and 19x11 +25 or +12 in the rears.
Front: 245/35R19
Rear: 275/35R19
I also currently have 235/35 front tires that are still good but, I take it they won't be ideal? Sorry for the noobness D;
Old Dec 19, 2015 | 07:34 AM
  #251
terrasmak's Avatar
If you don't mind.
Front: 245/35R19
Rear: 275/35R19
235 front with 275 rear will work, not the most ideal but it will let you get some life out of them. When they wear out, throw some 255/35 on.
IMO 255/35-19 and 275/35-19 are the most idea combo.
Old Dec 19, 2015 | 08:47 AM
  #252
More Lotion
Thumbs up
Thank you so much for the help! Been neglecting my Z and the forum for quite some time. Definitely coming back!
Old Dec 23, 2015 | 07:04 AM
  #253
Chris06Roadster's Avatar
Chris06Roadster
Quick question I wanna roll Varrstoen es1 I have BC BR COILOVERS I want a real flush set up I've been dieing to pull the trigger but don't know which offset to use. Don't want to rub I want maybe 245 35 19 +22 in the front and 275 35 19 + 12 in the rear what's your say? I rolled my fenders but I don't want too pull them will I fit? I just want a flush set up. Not much for stance
Front - 9.5
Rear - 10.5
Old Dec 23, 2015 | 08:38 AM
  #254
terrasmak's Avatar
Front - 9.5
Rear - 10.5
good plan it will be pretty solid. With that front setup, you will want to tweak the front camber to make it fit right
Old Dec 23, 2015 | 05:05 PM
  #255
miami1080's Avatar
miami1080
Default Need advice on wheels, tires and fitment
I've searched around but easily got lost trying to piece together everything from all the different threads. I really need some advice on wheels, tires and fitment.
I've got an 07 Z, currently stock. I am looking at purchasing these wheels: http://www.ebay.com/itm/JDM-18-WORK-EUROLINE-VIP-Dish-Wheels-Rims-5x114-3-4x114-3-18x8-18x9-5-CHEAP/161765977836?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D34492%26meid%3Dcb1f73013c9844669c13391911e43cfc%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D191757647005
I know that Work Eurloine DH wheels are "played out" but I like them. These wheels are 18x8 +20 (FRONT); 18x9.5 +38 (REAR). Im looking for an aggressive look. I want the wheels to line up perfectly with the body of the car with minimal space between the tire and the fender.
I spoke with a local tire shop and i asked him about going 255/40/18 in the front and 285/40/18 in the rear with these wheels. He recommended going 245/40/18 in the front. Does this sound right? I told him I dont want any tire gap and would like to lower the car also. He said that with this setup i probably wouldnt need to lower the car at all. Does this sound right? with this setup, would i need spacers to make the wheels line up with the body of the car?
Any help or insight at all would be greatly appreciated! I appologize up front for my lack of knowledge and really did spend a lot of time searching the forum but trying to piece together everything i read made me even more confused.
Ultimately, i want my car to look like this in terms of wheels, tires and fitment:
Old Dec 23, 2015 | 05:31 PM
  #256
terrasmak's Avatar
I've got an 07 Z, currently stock. I am looking at purchasing these wheels: JDM 18" Work Euroline VIP Dish Wheels Rims 5x114 3 4x114 3 18x8 18x9 5 Cheap | eBay
Take the 9.5's and throw a set of 20mm spacers on the, and run a 255/40-18 , then take the other set, take them apart and throw the 8 inch barrel in the trash. Rebarrel to 10.5 +15ish and run the 275/40-18 and call it good.
Old Dec 23, 2015 | 05:58 PM
  #257
miami1080's Avatar
miami1080
Terrasmack, thanks for the reply. Would the tire shop know how to take apart the wheel and throw away the 8 inch barrel and rebarrel to 10.5 +15ish?
Old Dec 23, 2015 | 08:32 PM
  #258
terrasmak's Avatar
You will need to find a shop like this http://www.wheelflip.com I did a quick google of rebarrel wheel to find them. There may even be one close to your area .
Old Dec 24, 2015 | 04:26 AM
  #259
miami1080's Avatar
miami1080
would i be better off buying theses instead?
http://www.ebay.com/itm/Work-Euroline-18-JDM-Wheels-4x114-3-5x114-3-VIP-ssr-volk-rays-weds-bbs-ccw-advan/191757647005?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D34492%26meid%3D965fe6387f3c404fb822f818cb69ab2d%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D191762744780
or these
http://www.ebay.com/itm/Work-Eurolin...FWa0R3&vxp=mtr
and not have to worry about doing any rebarrling? Or, if i want the look im after is a rebarrel something im going to have to do regardless?
I cant thank you enough for helping me out. As you have probably guessed, im not very well versed when it comes to this stuff.
Old Dec 24, 2015 | 04:42 AM
  #260
Pengu's Avatar
Pengu
I am getting Enkei RPF1's at the end of next month (I know extremely unique)
I'm getting 18x9.5 (front) and 18x10.5 (rear) +15 all around.
What is the meatiest setup I could run if I did a roll and currently have Eibach sportline springs on?
