PSA: When asking "will this rub"....
would i be better off buying theses instead?
Work Euroline 18 JDM Wheels 4x114 3 5x114 3 VIP SSR Volk Rays Weds BBs CCW Advan | eBay
or these
http://www.ebay.com/itm/Work-Eurolin...FWa0R3&vxp=mtr
and not have to worry about doing any rebarrling? Or, if i want the look im after is a rebarrel something im going to have to do regardless?
I cant thank you enough for helping me out. As you have probably guessed, im not very well versed when it comes to this stuff.
or these
275/35-18 front and 305/35-18 rear
noob here
2006 350z At Stock height
Front:
Tire size = 225 45 18
wheel = 18x9.5 +10 mm
Back:
Tire size = 245 45 18
Will these wheels work?
Front:
Back:
thanks!
Also what if I went ahead and did fronts 18x9.5 +12 and rear 18x10.5 +15 ?
Again same tire setup 225/45/18 and 245/45/18 at stock suspension.
I do plan on lowering in the future though, I just don't have the money for it at the moment.
That to will also work, I take it that you are trying to retain your current tires. Once they wear out 245/40-18 front and 275/40-18 rear, and it will still work fine when you lower the car
18x10.5+15 on the rear with a 265/35/18
18x9.5+12 on the front with a 245/35/18
i have rolled fender and on coilovers
is this going to work?
if i can id like to go up to 275 in the rear
I would seriously look into some different spec tires. The 265/35-18 you mention makes a great front tire and works well coupled with a 285/35-18 rear. People have even run larger rear tires on that Spec Eberl like a 295/35 or 305/35, then a 275/35-18 is the max front because of the narrow wheel you selected.
how would this set up fit?
can i keep the z aligned within stock camber specs and not rub?
08 Z Non-Brembo
18x10.5 22 f
18x10.5 15 r
eibach sportline springs
front and rear fenders rolled
265/40r18 all around
275/40r18 all around
and another thing can i make front offset 15 and fit that?
08 Z Non-Brembo
18x10.5 22 f
18x10.5 15 r
08 Z Non-Brembo
18x10.5 22 f
18x10.5 15 r
08 Z Non-Brembo
18x10.5 22 f
18x10.5 15 r
