PSA: When asking "will this rub"....
Old Apr 16, 2017 | 06:38 PM
  #381
travlee's Avatar
travlee
Master
Will fit fine, but will be hella sunk in. Look for something closer to +15
Old Apr 16, 2017 | 10:36 PM
  #382
terrasmak's Avatar
Originally Posted by MatthewBouchard
Well, I'm on my 3rd set of springs now(finally happy) and ready to order tires since my suspension will be complete this week, and tirerack has $100 off Hankook tires, so I'd like to be 110% I will more than likely have no issues even though I asked something similar a few months back and have seen similar setups.
Setup-
F= 18x9.5 +15
R= 18x10.5 +15
Tires= Hankook ventus v12 evo2. Front-265/35, Rear-285/35
Rolled QP's. Trimmed front fender screw. Eibach Sportline Springs.
I'd ideally like to keep the camber around -2* F&R if possible.
Any better recommendation on tire size? Not a fan of the hellaflush scene.
Install and drive, you will be good
Old Jun 19, 2017 | 03:41 PM
  #383
Gbastos's Avatar
Gbastos
Just want to make sure. Base 03 stock suspension.
18x9.5 +22 with 255/40-18 Fronts
18x10.5 +22 with 275/40-18 Rear
This will look fine and not mess anything up, rubbining etc? Thanks
Old Jun 19, 2017 | 04:59 PM
  #384
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Yes should be good to go. And look very nice.
Old Jun 19, 2017 | 05:23 PM
  #385
Gbastos's Avatar
Gbastos
Thanks man!
Old Jun 21, 2017 | 04:04 PM
  #386
OldSkool's Avatar
OldSkool
2009 ZR. Bought used but low miles. Has G37 wheels (yeah, I know...but I really like them) and 235/45/19 fronts and 255/40r19 rears. This setup doesn't rub but probably isn't optimal.
Old Jun 21, 2017 | 04:06 PM
  #387
OldSkool's Avatar
OldSkool
Sorry for the huge pic, shoulda resized. My bad.
Old Jun 22, 2017 | 06:47 AM
  #388
dboyzalter's Avatar
dboyzalter
Everyone is like 2009 350z wtf... The final 350z ever made right their, only available in the convertible... And yeah thay tire size is way big... Maybe in 18s it might be o.k. But not optimal... Also killed the stagger so im surprised your not having issues with slip light unless its a base model.
Old Jun 22, 2017 | 09:10 AM
  #389
OldSkool's Avatar
OldSkool
Yeah, "2009 350z" gets me weird looks at the parts counter...lol
With Mic's advice, I have ordered 245/35r19 and 275/35r19, and they should be installed tomorrow. I plan to use spacers in the front until I can go shopping for proper wheels in a couple months.
Thanks!
Old Jun 23, 2017 | 12:56 PM
  #390
live2ball's Avatar
live2ball
Just want to hear some opinions/double check:
I have an 05 base model, on stock suspension. Looking at getting 18x9.75 +20 wheels with 255/40 tires. Square set up. Does any one foresee any rubbing issues, suggest a different tire size, and what are your opinions on how it will turn out looking & performing?
Old Jun 24, 2017 | 04:58 AM
  #391
dboyzalter's Avatar
dboyzalter
I would bump up the size to 265/40/18 or 275/35/18 if your going to run square... And I would guess performance will be great... Cant go wrong with 255/40 front 275/40 rears.
Alternatively 265/35 front and 265/40 rear would also be good.
Old Jul 2, 2017 | 11:48 AM
  #392
live2ball's Avatar
live2ball
thanks for the advice! So you don't think I'd rub even with 265/40 at all 4 corners? Any other advice anyone?
Old Jul 16, 2017 | 06:36 AM
  #393
Moe747's Avatar
Moe747
ENKEI RPF1 SBC 18X9.5 +38 stock suspension, stock height, square setup and I don't know what size tires will be put on yet.
Old Jul 16, 2017 | 06:42 AM
  #394
travlee's Avatar
travlee
Master
Wont even be close to rubbing
Old Jul 16, 2017 | 09:25 AM
  #395
MicVelo's Avatar
350Z/370Z Tech Moderator
This. ^^^
Matter of fact, that's going to extend out by about 8mm. You could run some 15mm spacers to push them out a total of some 28mm and clear recommended 245/40 and 275/40s.
Or you can buy 9.5/10.5 +15mm setup, roll the rear lips, and be close to flush with not a lot of negative effect on steering response. (In my case the 9.5 +15/10.5 +15 setup is the MOST responsive setup I've run.)
Old Jul 17, 2017 | 08:47 AM
  #396
dboyzalter's Avatar
dboyzalter
On stock suspension the 10.5 +15 probably wouldn't even rub driving into the grand canyon...
18x9.5+38 is the wrong sized wheel, you will be disappointed.
Old Jul 17, 2017 | 02:21 PM
  #397
Moe747's Avatar
Moe747
17x10 +18 square, stock suspension, maybe .5" -1" lowered with aftermarket springs in the future. 275/40/17 all around.
Old Jul 17, 2017 | 03:04 PM
  #398
travlee's Avatar
travlee
Master
jeebus
Old Jul 17, 2017 | 03:57 PM
  #399
craig12895's Avatar
craig12895
Just seeing if anybody has any idea before I measure this weekend,
How far can a wheel go inward before it contacts any suspension components? I can work with either width and offset examples, or if anybody happens to know the actual distance between the wheel pad and and suspension components.
I will be at the garage this weekend but just seeing if anyone has any ballpark idea
Old Jul 17, 2017 | 06:55 PM
  #400
dboyzalter's Avatar
dboyzalter
Are you trying to get some ultra wide wheels?
