Decisions! - 18" TSW Cadwells?
Old Aug 4, 2013 | 09:34 AM
asoriano5843's Avatar
asoriano5843
Default Decisions! - 18" TSW Cadwells?
This dude is selling some 18" TSW Cadwells for $500. He painted them black. Should I pick these up and restore them or should I not even waste my time and just save up for better wheels???
Old Aug 4, 2013 | 09:37 AM
mr. sparco's Avatar
mr. sparco
Srsly dude? I'd rather have XXRs for the same price brand new.
Old Aug 4, 2013 | 09:43 AM
bealljk's Avatar
bealljk
Were they chromed before the black paint? I like TSW wheels in general, I don't necessarily like those…I had a set of TSW chromed Norgaros and the chrome deteriorated away and killed the wheels…I replaced them with an allow set of indy500s.
I would decline on this and save up for something you like.
Old Aug 4, 2013 | 09:44 AM
asoriano5843
Can you give me a link or something for that price? Cheapest i found was like $200 a wheel. I was leaning towards the 526 but not sure yet
Old Aug 4, 2013 | 09:46 AM
asoriano5843
Im guessing so. I asked him if he powdercoated them. He said he just painted them. I was also leaning towards 19s not 18s
Old Aug 4, 2013 | 10:35 AM
terrasmak's Avatar
Width and offset are needed before we can help you make decisions
Old Aug 4, 2013 | 10:41 AM
BY350z's Avatar
BY350z
God no, don't buy them...wheels like that belong on a scion not a Z and also looks like they are terrible offsets. At least save up a bit more for some xxrs or varrstoens if your on a budget.
Old Aug 4, 2013 | 10:57 AM
asoriano5843
what offset would you suggest? my friend is telling me to get some xxr 526s.
Old Aug 4, 2013 | 11:16 AM
samsniss350z's Avatar
samsniss350z
I'm in agreement with Mr Sparco here. These look they should be on a Range Rover or something similar
Old Aug 4, 2013 | 11:20 AM
asoriano5843
yea i decided against them now after researching on them. I really like the look of the varrstoen es6
Old Aug 4, 2013 | 11:28 AM
mr. sparco's Avatar
mr. sparco
Time to start saving.
Old Aug 4, 2013 | 11:42 AM
asoriano5843
Yup yup!
Old Aug 5, 2013 | 11:58 AM
Waiz's Avatar
Waiz
+1
From the looks of it, I am guesing it was from a FWD car
OP read this post within the TOP 100 FAQ:
Q: What wheel sizes and offsets do I need?
A: Generally speaking, there are a LOT of different combinations that people are running on their Z or G.
Let's get the basics out of the way first: You need a lug pattern of 5x114.3, width between 8 and 11 inches, and diameter of 17", 18", 19", or 20".
Here are some of the more popular wheel and tire sizes (for good reason) that people put on their Z's. There is no "RIGHT" answer but there is a limit to how big or small you can go.
18" combination:
Front 18" x 8.5" , Offset +15 to +25, Tires 245/40/18
Rear 18" x 9.5" , Offset +15 to +25, Tires 275/40/18
(lower offset such as +10 in rear is possible but may require rolling)
Front 18" x 9.5" , Offset +25 to +30, Tires 255/40/18
Rear 18" x 10.5" , Offset +28 to +35, Tires 285/40/18 or 295/35/18
(lower offset such as +23 in the rear is possible but may require rolling)
19" combination:
Front 19" x 8.5" , Offset +15 to +25, Tires 245/35/19
Rear 19" x 9.5" , Offset +15 to +25, Tires 275/35/19
Front 19" x 9.5" , Offset +25 to +30, Tires 255/35/19 or 265/35/19
Rear 19" x 10.5" , Offset +23 to +32, Tires 285/35/19 or 295/35/19
(lower offset such as +23 or wider tires in the rear is possible but may require rolling)
From this, you get the idea of what is required to go with smaller wheels like 17's, (typically lighter, faster acceleration), or bigger wheels like 20's (bigger, heavier, usually makes you feel slower).
Get to know how to use the following tools and you will be able to figure out for yourself the correct offsets and tire sizes you need:
Tire size calculator (click)
Wheel Offset Calculator
Certain combinations of LOW OFFSET and/or WIDE WHEELS will require what is known as "fender rolling" or "fender cutting".
If you are not familiar with the term "fender rolling", here is a quick but useful lesson you can learn in a couple of minutes: Go outside to wherever your Z is parked. Run your fingers along the inside edge of a REAR fender just above your tires. You will feel a sharp edge and a flap of metal sticking inward towards the car. Now, go up to the FRONT fender, and feel the inside of the fender again. You should notice that the flap of metal has been "rolled" upwards on the front fenders. This is exactly what fender rolling is all about. The rear fenders will need to be rolled to make room for wide wheels or low offsets, or else your tires may rub on the metal when you take hard corners or hit bumps. Any experienced wheel/tire shop should know how to roll a fender. If you go to a shop that does not seem like they know what they're doing, get out of there.<!-- google_ad_section_end -->
From what you posted in this thread you should go ahead and read the entire thread too to become better acuainted with the car:
https://my350z.com/forum/2003-2009-n...questions.html
<!-- / message --><!-- edit note -->
leonchus
Sep 29, 2015 07:04 AM
Z&Jet-Pilot
Oct 16, 2002 02:51 AM
99M3
Sep 5, 2002 09:39 PM
Loaner
Aug 19, 2002 06:21 AM
3rdpower
Jul 2, 2002 09:46 PM
