Quick question. Was wondering if you guys think that the studs would clear this. I measured the depth and it's about 15mm. Our studs are 25mm long and I want to run a 15mm or 20mm. So it would only poke out about 5-10mm. Just wanted to be sure and not waste money on the wrong spacer.
Wait what exactly are you asking? Are you trying to use spacers with these wheels and asking if it will work? If so, yes but you will want to either get spacers with built in studs, or get some extended studs to replace your oem ones as you definitely DO NOT want to run spacers without extended or built in studs. As far as what size of spacer, give us the wheel specs and what kind of look you are going for/lowered/how aggressive
I'm asking if a bolt on spacer setup will work with this wheel. The rear is 19x11 +20 on a 255/35/19. Decently aggressive I'm already pretty low but not slammed and maybe run like around -3.0 camber in the rear.
Don't buy bolt an spacers. Simple and easy, do it right with extended studs.
The key to spacer safety is torquing them down correctly. I run a dangerous amount of spacer so I won't recommend it. But, I've run 20mm for years with no issue.
