1st issue with my "new" ZR?
Old Sep 1, 2013 | 12:35 PM
bj-99's Avatar
bj-99
Default 1st issue with my "new" ZR?
Ok. Tire pressure light came on. Checked all 4 & they are @ 34 PSI. So a sensor has quit. How do I find out which one? My Corvette reports each wheel individually, makes it easy.
Old Sep 1, 2013 | 12:46 PM
NoQuestionZ's Avatar
NoQuestionZ
Go to Discount Tire (that's where I went with TPMS issues. They can check/reset them on the car for free. One may have died and they should be able to see that too.
Old Sep 1, 2013 | 01:05 PM
bj-99's Avatar
bj-99
Thanks. Great to know
Old Sep 1, 2013 | 04:51 PM
terrasmak's Avatar
What year is your car?
Old Sep 1, 2013 | 05:35 PM
calidrew909's Avatar
calidrew909
this is a 350z forum
Old Sep 1, 2013 | 05:44 PM
boost'nvq35hr's Avatar
boost'nvq35hr
Wink
Wait this isnt the 350 V8 ZR Corvette forum? damn you google.
Old Sep 1, 2013 | 07:54 PM
bj-99's Avatar
bj-99
2007
Old Sep 1, 2013 | 08:40 PM
terrasmak's Avatar
2007
Ok, 03 to 06 you can see the PSI in you multi display. I wonder why they got rid of that feature in 07. You will probably need a dealer to check it out.
Old Sep 2, 2013 | 11:21 AM
Dealsgap's Avatar
Dealsgap
Default False code
One of my sensors on my 08 gave a false code about a year ago. I knew that nothing was wrong with the tire (I check them pretty regularly) so I just disregarded the warning until I went in for my next oil change at the dealorship.
They reset it for me and did not charge me anything. Has been fine ever since...
Old Sep 2, 2013 | 08:46 PM
Castor771's Avatar
Castor771
My tpms light went on recently but I was only able to accurately determine the psi on the front driver side was triggering the light using an accuguage pressure tester. The pressure reading on my portable air compressor was inaccurate.
Old Sep 3, 2013 | 01:46 PM
HK350 Z's Avatar
HK350 Z
They stopped because poeple were putting the sensors on the incorrect tires so that they couldnt tell which one had the issue.So Nissan decided to make it easier and hassle free if the sensors get swapped by accident.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
