just bought new wheels..they don't clear brembos
Old Aug 15, 2014 | 08:54 PM
koyv90's Avatar
koyv90
Default just bought new wheels..they don't clear brembos
Ugh. Just drove two hours to pick up some wheels. 18x8.75 and 18x9.75 +20 on each. Rear clear fine but fronts do not clear. How can I fix this? I'm under the impression I need spacers extended wheel stud's and extended lug nuts. Also was told that running spacers on the front will make it more out then the rear and look bad.. Any suggestions ?
Old Aug 15, 2014 | 09:15 PM
AroundMyHorn's Avatar
AroundMyHorn
Sell them and buy proper fitting wheels?
Old Aug 16, 2014 | 02:10 AM
terrasmak's Avatar
Please post offset and how big of a spacer you would need to clear the Brembo's.
Old Aug 16, 2014 | 11:17 AM
koyv90's Avatar
koyv90
They are +20 offset. And I think a 10mm would clear or 5mm even
Old Aug 16, 2014 | 11:43 AM
Bmurray350z's Avatar
Bmurray350z
Try 5mm. As they're just slip on spacers and don't require extended studs/lug nuts. Anything larger than 5mm will, though.
Or you can get bolt on spacers.
Old Aug 17, 2014 | 09:47 AM
faiz23's Avatar
faiz23
FEZZZZZZ
Ship me your Brembos and I will ship you my dual piston OEM calipers. Problem solved and no need to risk messing around with spacers or lugs / studs.
Old Aug 18, 2014 | 03:17 AM
suprasam's Avatar
suprasam
Keep in mind different manufacturers can have different inner barrel and spoke angle dimensions. What brand of wheel are they and what is the part that is not clearing?
Old Aug 18, 2014 | 10:06 AM
SQuaLZ's Avatar
SQuaLZ
Most important question!
Is the caliper hitting the barrel or the spoke?
Old Aug 18, 2014 | 10:49 AM
Waiz's Avatar
Waiz
As others have stated, without knowing how close the wheel is to the caliper we can't suggest a solution
Some wheels just won't work with Brembo's unless you run a massive spacer so this should have been something you researched prior to buying the wheels.
From your specs I am guessing they are some sort of XXR's?
Old Aug 18, 2014 | 10:54 AM
travlee's Avatar
travlee
Master
but that makes too much sense
Old Aug 18, 2014 | 09:45 PM
koyv90's Avatar
koyv90
spoke i think?
yea xxr 527. i got 5mm spacers they barely clear might want to get 10mm...
Old Aug 19, 2014 | 07:06 AM
iideadeyeii's Avatar
iideadeyeii
An 8mm will not need extended studs. 10/12 will
Those stick out 20mm more in the front and 32mm in the rear. FWIW
Old Aug 19, 2014 | 07:07 AM
iideadeyeii
I will 2nd this offer and add $20 and a BK gift card with $3.12 remaining
Old Sep 30, 2015 | 08:05 PM
faiz23's Avatar
faiz23
FEZZZZZZ
My final offer is OEM dual piston in exchange for your brembos that don't fit along with $21 dollar cash and $5 at in and out....take it or leave it....i know I am bumping this thread that is over a yr old
Old Oct 1, 2015 | 05:26 AM
iideadeyeii
OK, ok, ok, OEM calipers AND rotors, $21.01 paypal as a GIFT, 2 sugarfree redbulls and i'll shave an eyebrow off
Old Oct 5, 2015 | 08:57 AM
driftsucky's Avatar
driftsucky
I'm still trying to figure out why you drove anywhere other than down the street for XXR's.
Old Oct 5, 2015 | 11:48 AM
vex008's Avatar
vex008
once 5mm clear with lugs tighten you don't need to go with a wider spacer as its not going to flex, travel or change distance due to bumpy roads or any other conditions i can imagine by your reasoning.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Mw870
Sep 10, 2015 07:50 PM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
