Will this wheel for help me please new to this car game!!!
Old Sep 5, 2014 | 02:55 PM
zahin3265's Avatar
zahin3265
Default Will this wheel for help me please new to this car game!!!
Will these wheels fit my stock tires which are 17x8
Look at this on eBay:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=360885283681
4 New 17X8 42 Offset 5x114.3 MB Motoring Weapon Gun Metal Wheels/Rims
Old Sep 5, 2014 | 05:00 PM
soc_monki's Avatar
soc_monki
yes, but the offset is horrendous. the 17x8 weapons (which i have on the front of my Z) are i think 28 offset...check discounttiredirect.com to be sure. i have the 17x9 on the rear which are 17 offset.
if you get the 42 offset wheels they will sink further into the wheel well, and it will look like crap unless you have 30mm + spacers. i have 20mm for mine, but they arent on right now. still looks nice without them (plus the rears would rub...still have to roll my fenders).
and FYI, stock 17s are 30 offset in front, 7.5 inches wide. rears are 33 offset, 8 inches wide. if you want a square setup i recommend going 17x9 front and rear. on stock tire sizes they will be slightly stretched. go to 245/45/17 front tires and 255/45/17 rear, or 275/40 front and rear for wide meats. look around, search, do your homework.
Old Sep 5, 2014 | 05:37 PM
travlee's Avatar
travlee
Master
i have a pair of these exact same wheels sitting in my garage collecting dust.... 17x9 +27, i initially bought them for track wheels and then decided against tracking car. too bad your aren't closer
Old Sep 5, 2014 | 09:49 PM
zahin3265's Avatar
zahin3265
Default Wheel figment
So if I get 30mm wheel spacers it will work out with no serious issues for both rear and front ??
Old Sep 6, 2014 | 08:03 AM
Steelcyclone's Avatar
Steelcyclone
Just get these http://www.ebay.com/itm/2-New-17X9-17-Offset-5x114-3-MB-Motoring-Weapon-Gun-Metal-Wheels-Rims-/310901764516?pt=Motors_Car_Truck_Wheels&hash=item48633071a4&vxp=mtr then you don't need to run spacers and you get wider tires at the same time. win win if you ask me. But if you want to run 17x8 to keep your tires you have on now then I don't know, I think it's a waste to buy new wheels and keep those tiny tires on. If your on stock suspension you probably can get away without a fender roll, but if you lowered your more than likely going to need one.
Old Sep 6, 2014 | 08:19 AM
Waiz's Avatar
Waiz
Why are you so set on keeping your stock tires, strictly budget?
You are selling yourself short by sticking with the skinny stock tires if you're even going to both upgrading to aftermarket wheels
I would suggest you get at least 18" wheels and tires suggested in this post in the Top 100 FAQ
https://my350z.com/forum/2003-2009-n...ml#post2487452
I have a feeling you will regret your purchase once you become more informed
Old Sep 6, 2014 | 06:13 PM
soc_monki's Avatar
soc_monki
spacers are no big deal...but i wouldnt recommend those wheels, as i said above. there are better offset options available in those wheels. like the ones i have. same wheels, but 17x8 for the front, with a 28 offset, and 17x9 rear with a 17 offset as posted above as well. and im on stock tire sizes until i wear them out. 225 front and 235 rear. they are slightly stretched (too skinny for the width of the wheels) but they work, and are almost new, so im not throwing that money away.
and i have 20mm spacers for my wheels, but dont have them installed because the rear fenders need to be rolled or ill rub, and i took the fronts off because i did the brakes recently and didnt have an assistant to hold the brakes so i could torque the nuts down. still looks fine, but once i get my fenders rolled ill put them back on.
as for if youll be unhappy with the wheels (size wise), im perfectly content with my wheels. 18s may look slightly nicer, but once i get tires more suited for the width of my wheels it will look better. i like the fatter tire look anyway, but i can appreciate all options.
take your time and do some research...learn about offsets and what wheel sizes look like on your car, as well as tire sizes and widths. go to http://www.willtheyfit.com and play around with the calculator there to see how things work a little better.
Old Sep 6, 2014 | 10:45 PM
RedScytheZ's Avatar
RedScytheZ
This. Just save a little longer and do it right. No one is saying do it expensively, just right.
Old Sep 8, 2014 | 03:38 AM
travlee's Avatar
travlee
Master
but that makes too much sense, if he wants to half *** his car then let him.... the we can say we told you so later on
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
davidm350
Oct 31, 2015 02:28 PM
sherm
Sep 10, 2015 11:02 PM
