Wheel Setup Questions
Old Oct 24, 2014 | 05:06 PM
joey502's Avatar
joey502
Default Wheel Setup Questions
im about to buy some 17x8.25 rims for my z and it says the backspacing is 5.61 Is this the correct fitment for me? thanks in advanced guys
Old Oct 24, 2014 | 05:10 PM
RUNWDVL's Avatar
RUNWDVL
Umm no.
Old Oct 24, 2014 | 05:11 PM
travlee's Avatar
travlee
Master
just say no on 17's.... they look small on the car. 18s at least, and look at 9.5 width with a +15 (ish) offset
Old Oct 24, 2014 | 05:14 PM
joey502's Avatar
joey502
thanks guys. i only have a $1000 budget. Any suggestions on rims? Gram light titanium finish are on my wishlist but unfortunetly i dont have that kinda cash
Old Oct 24, 2014 | 05:15 PM
travlee's Avatar
travlee
Master
thousand bucks will get you some decent xxr's or mb's.....
i have the mb battles and they look decent, and will be just over 900
Old Oct 24, 2014 | 05:17 PM
joey502's Avatar
joey502
im looking at the xxr 530s in chromium black. Its probably what ill end up getting
Old Oct 24, 2014 | 05:19 PM
travlee's Avatar
travlee
Master
do 18x9.5 on all corners... OR 18x9 front and 18x10 rear
Old Oct 24, 2014 | 05:23 PM
joey502's Avatar
joey502
would i have to roll fenders on the 18x9 with 20mm offset?
Old Oct 24, 2014 | 05:26 PM
travlee's Avatar
travlee
Master
no, you could do an 18x9.5 +23 in rear and not rub, i even added a 5mm spacer (essentially a +18) and didn't rub, but when i went to a +15 i rubbed (with a 275/40 tire)
Old Oct 24, 2014 | 05:36 PM
joey502's Avatar
joey502
can someone help me out on these specs? Will they fit properly. I have tried searching for fitment guides but no luck
http://www.nlmotoring.com/XXR-530-Wh...n.htm?CartID=1
Old Oct 24, 2014 | 05:49 PM
travlee's Avatar
travlee
Master
did you not read what i posted???? they will fit, but they will be narrow and sunk in
Old Oct 24, 2014 | 06:04 PM
joey502's Avatar
joey502
i did but they only come in these odd sizes. i just ordered the 18x9.75 20mm offset... now for tires
Old Oct 24, 2014 | 06:17 PM
travlee's Avatar
travlee
Master
you will be okay with those... to keep traction control liking you, try 255/40 front and 275/40 rears
Old Oct 24, 2014 | 06:19 PM
joey502's Avatar
joey502
first thing i do when i start my car is turn tc off. is that bad? ive always heard better mpg when is off
Old Oct 24, 2014 | 06:21 PM
travlee's Avatar
travlee
Master
i do the same, unless it is raining or something
Old Oct 24, 2014 | 06:24 PM
joey502's Avatar
joey502
thanks for your help and advice man. Its appreciated
Old Oct 24, 2014 | 06:25 PM
travlee's Avatar
travlee
Master
anytime......
Old Oct 24, 2014 | 06:27 PM
travlee's Avatar
travlee
Master
just fyi, on my car with a 9.5 +23 up front with a 255/40 tire, and almost zeroed out on camber, i was rubbing on the screw that holds the fender liner in.... you might want to go 245/40 up front, this will roll the shoulder of the tire in some giving you more clearance
Old Oct 24, 2014 | 07:56 PM
Waiz's Avatar
Waiz
Thread retitled, please title your future threads according to what you are asking
416blueZ
Jun 11, 2024 10:56 AM
davidm350
Oct 31, 2015 02:28 PM
PLAYDIRTY
Oct 12, 2015 07:45 AM
