Can I get see some setups on 245/35/19's Fronts & 265/35/19 Rear. Looking to run the same setup for 19x9.5 & 19x10.5 wheels , thank you!
This is exactly that set up except for the double stagger 18 up front (Nismo combination but section widths exactly the same).
Most important to note that these are 18x9.5 +34 up front (with only a 5mm slip-on spacer making them +29mm effective). This has proven to be the best responding/handling setup between running them without a spacer at +34 and with a 15mm spacer making them +19.... horrid turn-in response. And running them at +19 rubbed on bumps. Bleah.
Rears are basic 19x10.5 +19 with the 265s.
Volk set-up 19x9.5 +19F / 19x10.5 +29R No spacers.
These are run with the proper 245/275 tire combination.
Will eventually be putting on my Z34N wheels (9.5/10.5) but those wear 255/285
