Tires, yearly use: 3,500 miles daily driving + 5-10 passes on the 1/4
Old May 13, 2017 | 05:49 PM
drozzy's Avatar
drozzy
Default Tires, yearly use: 3,500 miles daily driving + 5-10 passes on the 1/4
As the title says, looking at replacing current tires (RE050A's) with a new summer performance set, somewhat double duty with the few passes at the 1/4 mile around the year. I would like to get 3 years out of them (anything beyond that is gravy), meaning about 10,500 miles and 30 passes tops... my commute is not overly bad for pot holes, the worst two bumps are bridge 'joints' if you will.
It's a 5AT, so I can warm up the tires in 1M spinning over 20-30 ft before I line up at the lights. Not looking to break records, just having some fun at SMP mix & match events in Shannonville ON. No suspension mod really, just Eibach sways on MED settings front and rear. I also got this Stillen engine damper brace but I doubt it factors in much in straight acceleration.
It's the GT package, so I need tires for RAYSv2's in stock sizes of 265/35R19 + 245/40R18, unless some of you with experience at the strip with stock suspensions can pitch up a better size combination for those rims. I suppose I could establish a baseline with the RE050A's first, but I'd like to get opinions on tires that fit the bill so I can watch out for deals. Thanks!
Old May 14, 2017 | 07:08 AM
coletrickle74's Avatar
coletrickle74
Don't do burn outs at the track on street tires, just let some air pressure out of the rears before you go. Any decent summer tire will be the same for what you're using it for.
Old May 14, 2017 | 08:00 AM
drozzy's Avatar
drozzy
Given their OEM pressure of 35-36 (off the top of my head) would you get them down to 28-29 or closer to 31-32?
Yeah I'm not planning on cheaping out anyway, the very lower end of my range falls on the BFG Sport Comp 2's.
Old May 14, 2017 | 08:47 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Toyo Proxes R888
Old May 14, 2017 | 01:45 PM
drozzy's Avatar
drozzy
Originally Posted by Atreyu'z 350
Toyo Proxes R888
https://www.tirerack.com/tires/tires...el=Proxes+R888
https://www.tirerack.com/tires/tires...l=Proxes+R888R
No, just no. A) not nearly enough treadwear to put 3,500 miles of daily driving / year on them, B) no matching sizes for the RAYSv2's whether you look at the reg 888's or the 888R's on Tirerack.
Old May 14, 2017 | 02:16 PM
coletrickle74
Just experiment with pressures at the track, only way to really do it. Too many variables.
Old May 14, 2017 | 05:04 PM
Atreyu'z 350
Oh, so you DO know how to search.
Old May 14, 2017 | 06:15 PM
drozzy's Avatar
drozzy
What the fukk is your problem? Why are you wasting your time, my time with sarcasm?! The fukk is wrong with people, just don't say you don't have a god damn opinion lol...
Old May 15, 2017 | 05:51 AM
Atreyu'z 350
lol Wow, you're a tough guy. I'm scared now.
Old May 15, 2017 | 06:04 AM
travlee's Avatar
travlee
Master
snowflake drozzy got triggered real quick
