What size wheel to run with my tires?
Old Aug 30, 2018 | 02:40 PM
Jsully24's Avatar
Jsully24
Default What size wheel to run with my tires?
Front tire 225/45/18
back tire 265/35/18
what size wheel do i need? 8.5 front or 9.5 for front?
10.5 in the back?
Old Aug 30, 2018 | 03:06 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
back tire 265/35/18
10.5 in the back?
8.5 is good for fronts, out back you have a little leeway.... 9.5 to 10.5 works fine. But be aware, this much stagger will probably alter the steering attitude. You might be dialing in a bit more understeer with this because the fronts will wash out well before they should vis a vis rear. Would suggest a larger front tire set up with a F-R delta of no more 20, maybe 30mm. Or adjustable sway bars to increase the rear roll stiffness to compensate for the big stagger and allow the backend to move out in tune with the front.
Old Aug 30, 2018 | 03:42 PM
Jsully24's Avatar
Jsully24
what tire would you suggest in the front? I just put new fronts on. Im on coilovers and im low so i feel like a bigger tire will just rub. My traction control or “slip” comes on doing certain turns
Old Aug 30, 2018 | 04:27 PM
MicVelo's Avatar
OK, since we're starting afresh, the proper handling set up means going wider to a limit with same height tires (rolling diameter/circumfrence) to keep the ECU happy with a set that is the same as what the car had on it stock (or within a reasonable stretch.), wheels that are wider without causing wider tires to rub meaning they must have the proper offset.
The acknowledged go-to 18" set up is:
Either:
18x8.5 F and 18x9.5 R with offsets in the mid 20s (say +22 up to factory +30) wearing 245/40-18 F and 275/40-18 R
OR
18x9.5 F&R with offsets in the +22 area with same tires as above
OR
18x9.5 and 18x10.5 in the +22 to +25 R with same tires
Obviously there are permutations and combinations in between that work but these are the most popular on Z33.
None of these should rub unless you're down in the "doesn't help any going that low" zone.... meaning -1.5" or lower on the street.
The reason your slip/TCS is triggering is the tire height stagger is outside of the 3% tolerance range F-R; meaning your wheel speed sensors are telling the ECU your rear tires are slipping. Those 265/35s are way short and way wrong. You NEED to get more height into the rear tires.
Old Aug 31, 2018 | 04:41 AM
travlee's Avatar
travlee
Master
Old Aug 31, 2018 | 05:33 AM
JCat's Avatar
JCat
Very happy with my similar setup:
https://my350z.com/forum/wheels-and-...ml#post9513000
Old Sep 1, 2018 | 09:15 PM
terrasmak's Avatar
Why are you wanting to run front tires on the back of your car? 265/35-18 on a 18x9.5 or 18x10 works great up front
GT-ER
Aug 12, 2010 05:05 PM
eez
Oct 8, 2007 09:20 AM
emtae
Dec 22, 2006 05:37 PM
live steam
Apr 9, 2005 12:13 AM
