Would these 20 Niche wheels fit?
Ive looked and cant seem to find anything. In a hurry to get wheels ordered but not sure if Ill be able to make these fit.
Front: 20x9 +35mm
Rear: 20x10.5 +40mm
Thank You
link: https://www.ebay.com/itm/Niche-Vice-....c100889.m5204
Front: 20x9 +35mm
Rear: 20x10.5 +40mm
Thank You
Fronts will fit, the rear will rub on the inside and require a 10mm or larger spacer to clear.
With that said, I would order something that's not made to be a boat anchor
I ran 20 wheels on my setup for awhile ... 38th worst decision of my life
go with a lightweight set of 18 ... OEM track wheels or ranked RPF1s are great choices and reasonable priced.
I have the forged rays mine is track but the rear wheel is chipped and I dont have any clue how it holds air so I need a new wheel. Figured I might as well get a clean set. Im not worried about speed or performance. I dont race, I just want a clean lowered setup
Thanks but I didnt ask about that. I wanna know if I could stuff them under the fender. I have forged 18s and want something cleaner. Those are too small to me
350Z/370Z Tech Moderator
So you wanna stance, not dance. No problem with that but.... as its been said, those offsets are more set for Honda/Acura versus Z car. Stick with around +20 to +30 for clearances sake. Yes, you can mount them but beware inner clearance issues (as was mentioned).
Thanks for answering the question without negative input. Not sure why thats so difficult. I ended up getting a set of ESR RF2 forged F:19x9.5 +22 R:19x10.5 +22
ESR has some nice looking standard-cast wheels but they're pretty heavy and may not be suitable for track days (or maybe they are, I don't know... but price point and absence of weight info tells me they're street-only wheels.)
In for pics!
Nice wheels. If you haven't mounted them yet, would be curious to know what the weight of these are. The new(er) rotary/rolled forge RF1 and RF2 might be a good option for people looking for lower weight/higher strength "budget wheels". (At less than $300/copy and what seems like decent construction, they fall into that category and fit your bill (street only) to a T.)
In for pics!
In for pics!
In for pics!
In for pics!
F: 19x9.5 +22 weighed about 23.3lbs
R: 19x10.5 +22 weighed about 25.1lbs
the look and feel great. Tires go on tomorrow and pics will be posted this weekend
SamH
May 31, 2008 11:50 PM
