VDC Help
Old Apr 8, 2004 | 02:57 PM
DriftinZ's Avatar
DriftinZ
Question VDC Help
Hey guys, i woulda used a search to try an find this but its not working. I'm still a neebiee and wasent able to find this anywhere. So hopefully someone can help. I plan on running E/T streets next week up at our local dragstrip and i read that you cant do a brake stand even with VDC off. I read it will think somethings wrong a kick on VDC while in a brake stand and bog the car out. Is there a way to totally dissable it? I ran lastnight on my Track wheels w/ the stock tires...EMBARRASSING. I even let the pressure down to 20psi, stupid TPS pressure warning was beeping all over the place, annoying. Whats it gonna do when i have different wheels on the back? Sorry for so many questions just kinda new to this. I saw 3 Z's lastnight up at New England Dragway, didnt get a chance to talk to them cause i was to busy swearing and cursing at my factory tires. Thanks Alot!!!
Old Apr 8, 2004 | 11:37 PM
jckolnturn's Avatar
jckolnturn
It's not the VDC that causes the problem, the car cuts the throttle when you push the brakes. There is a thread somewhere explaining what you have to do to trick the car so it doesn't know you are gassing and braking at the same time. I think search is still broke, maybe someone else can help point you in the right direction.
Old Apr 9, 2004 | 12:03 AM
D'oh's Avatar
D'oh
I think the fix was to remove either the third tailight fuse or ABS fuse. I can't remember for sure either, but I think it had to do with pulling fuses.
12secZ posted a bit about it, since he has an auto, but he's got about a million posts so it would be tough to find the info without the search working.
Good luck!
-D'oh!
Old Apr 10, 2004 | 12:30 PM
DriftinZ's Avatar
DriftinZ
Thanks Alot guys, sorry for the long thread responce. Hmmm I did see someone about the fuse thing. Just wanted to make sure before i go pulling fuses. Anyone else know for sure? Thanks again guys
Old Apr 10, 2004 | 02:05 PM
teh215's Avatar
teh215
The search does still work for screen names so, that may help limit your search results ... I definitely would not yank the ABS fuse just in case you need to brake hard. I would rather have a slightly lower ET than hit the wall if the brakes locked up.
Old Apr 10, 2004 | 02:08 PM
Melissa's Avatar
Melissa
have to pull the fuse for the brak lights......the car cuts the power by 30% when you hit the brakes
hope this helps
Old Apr 10, 2004 | 04:04 PM
DriftinZ's Avatar
DriftinZ
Hmmmm...so to be able to do brake stands you have to have the tail fuse pulled....so no brake light huh? i just tried pulling the abs fuse and it still died down while trying to hold a brake stand...so gay. still blows nasty donutes though. Just had alittle fun in a parkinglot, recoreded it with a digi camera, i'll post it back if anyone wants to check out me an my z having alittle fun. It was the first donute in my car...so its a special one
aarrgghh
May 1, 2022 11:04 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
NiQk
Dec 17, 2002 10:48 AM
koolzero
Nov 20, 2002 12:53 PM
audball
Oct 21, 2002 12:00 PM
