Has anyone tried transporting 4 wheels/tires inside the Z?
Old Aug 6, 2004 | 12:29 PM
J Ritt's Avatar
J Ritt
Default Has anyone tried transporting 4 wheels/tires inside the Z?
I just picked up some track wheels/tires. I was wondering if anyone has tried removing the passenger seat and hauling wheels? If so, do all 4 fit? I'm guessing they probably won't fit, but it's worth asking before I yank the seat and try myself tomorrow. Thanks.
Old Aug 6, 2004 | 12:36 PM
Moroccan_Mole's Avatar
Moroccan_Mole
you can put 2 front wheels in the passenger seat; put the seatbelt through the middle to hold them in place. remove the spare tire and put 1 rear wheel in the spare tire area and the last rear wheel over the strut bar and resting in the middle between the 2 seats.
make sure you bag all of your wheels/tires.
Old Aug 6, 2004 | 01:48 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
not with tires on them...
i was barely able to get 4 18's in my car out of the box!
Old Aug 6, 2004 | 01:59 PM
apex locator's Avatar
apex locator
i think i read awhile back that raceboy was able to fit all 4 of his 17" enkei w/ tires in the z.....forgot how
Old Aug 6, 2004 | 05:14 PM
hurahn's Avatar
hurahn
Try the two smallest(width wise) side by side in the passenger seat. Put one rear tire under the strut and the other over the strut between it and the seats. Hatch probably wont close so just drive slow.
Old Aug 6, 2004 | 05:35 PM
Jason@Performance
Performance Nissan
problem is... there is only 18" of space between the rear STB and the rear of the car...
strip your interior tht goes up to 21"
Old Aug 7, 2004 | 03:25 AM
johnlotusboy's Avatar
johnlotusboy
I've seen a guy at an autocross that had 4 with an aftermarket jack, air tank and helmet along with other stuff. They were 18" w/tires he left the spare at home.
Old Aug 7, 2004 | 12:29 PM
Audito350Z's Avatar
Audito350Z
raceboy did it by removing the front passenger seat... plenty of room when you do that! I think he got three of them in the empty space and one in the spare tire well....
Old Aug 9, 2004 | 12:15 PM
John's Avatar
John
I'm curious as to whether you can stack two wheels on top of each other in the back if you remove the spare tire, rear plastic interior, and the plastic on the hatch (maybe the rear wiper w/ motor too). Anyone given this a try?
Old Aug 10, 2004 | 08:50 AM
03Z33's Avatar
03Z33
4 wheels with tires will fit as described above. I do it all the time if you remove the ps seat then you can fit a fifth wheel up front. the wheel over the strut bar should not be over 10in wide and no more than 265 tire (most fronts are not that wide anyway...) and no you can not stack two wheels in place of the spare, even a stock front will not fit with the skinny spare
Old Aug 14, 2004 | 08:10 AM
J Ritt's Avatar
J Ritt
Thanks for the input guys.
Old Aug 14, 2004 | 09:31 AM
John's Avatar
John
Damn. Even if you remove all the plastic from the rear hatch?
Old Aug 15, 2004 | 02:58 AM
03Z33's Avatar
03Z33
Maybe with one of those fancy carbon hatches there is more room ?
Old Aug 15, 2004 | 06:59 AM
speedzz's Avatar
speedzz
Know anyone with a truck?
Old Aug 17, 2004 | 04:19 AM
Jux2p0ze's Avatar
Jux2p0ze
I switched out my 18" tourings for 18" tracks so had to lug around 4 wheels/tires. put the 2 front wheels in the back, pad them if you like w/ light towels so you don't scratch the interior. place 1 of the rear wheels where the passenger's feet should go. Push the seat all the way back and you can put the remaining wheel/tire on the seat w/o having to remove the seat or spare tire. Still plenty of room for helmet and minor tools behind the rear console and rear strut. Cheers.
Old Aug 17, 2004 | 04:26 AM
John's Avatar
John
You're able to get a wheel/tire in the passenger footwell? I'll have to try this tonight...
Old Aug 17, 2004 | 08:58 AM
DmitryZ's Avatar
DmitryZ
This worked very well with my nismo wheel/tires... rear ones in the back
Dmitry
Old Aug 17, 2004 | 11:10 AM
John's Avatar
John
As much as I'd like to do it the way that puts one over the plastic behind the heatrests, the x-brace of my roll bar prevents this...
Old Aug 17, 2004 | 11:56 AM
phoenixZ33's Avatar
phoenixZ33
Two in the passenger seat, one in the spare tire well and the other up on the ledge between the two speakers (behind the strut bar) seems to be the easiest way.
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
