enth. wheels went to track rays
Old Aug 27, 2004 | 10:22 AM
4myZ350's Avatar
4myZ350
Default enth. wheels went to track rays
i got some track rays from another member all was ok got them on at 12k'ish--- i have 15800 and my brake pad are gone. did i do something wrong . the wheels are on the correct places.
is there something that needed to be done when switching?
all of a sudden all kinds of noises even when not on brakes just driving.
Old Aug 27, 2004 | 10:37 AM
zand02max's Avatar
zand02max
Are they the stock tires also? If they are, make sure the 225's are up front and 245's in the rear. Ensure the arrows on the tires are facing the correct way. They are one-way directional tires.
I have Track Wheels and have had no problems.
Advice, might be to take it to a tire shop and let them look at it. Might be your brakes though. I have had brakes last 70,000 miles, but it all depends on the driver and how he uses the brakes.
Old Aug 27, 2004 | 10:39 AM
Poison123's Avatar
Poison123
Google Bot
Have you been driving hard? I think the average life of the stock pads on the Z are between 15k-20k it seems like.
Old Aug 27, 2004 | 11:26 AM
4myZ350's Avatar
4myZ350
[QUOTE]Originally posted by zand02max
[B]Are they the stock tires also? yes
did you upgrade to track wheels?
Old Aug 27, 2004 | 11:29 AM
4myZ350's Avatar
4myZ350
yes
any ideas on noise when not braking
it seems all brake related
Old Aug 27, 2004 | 11:30 AM
zand02max's Avatar
zand02max
[QUOTE]Originally posted by 4myZ350
[B]
Yes,I have Track Wheels and Stock Tires.
Old Aug 27, 2004 | 01:48 PM
4myZ350's Avatar
4myZ350
if the car came w/ rays then why would you think that rays in place of enth. wheel would be the same
Old Aug 27, 2004 | 01:58 PM
Iezzi's Avatar
Iezzi
if you did not torque the wheels correctly your breaks can be affected check all your lugs 80 lb feet is the correct torque spec
Old Aug 27, 2004 | 02:06 PM
4myZ350's Avatar
4myZ350
i'll check that thanks
Old Aug 31, 2004 | 08:07 AM
4myZ350's Avatar
4myZ350
the wheels where torqued at 80lbs.
(1) any one had ANY problems going from 17" stock to the 18" rays?
(2) does any know what the story is w/ the G35 get a warrenty extention( to 35,000) on there brake pad ?
Old Sep 7, 2004 | 08:06 AM
4myZ350's Avatar
4myZ350
G35 brake problem? anyone !!!!!!!
Old Sep 7, 2004 | 08:39 AM
maxipad96's Avatar
maxipad96
Your mileage is normal for brake wear.
My Enthuis. Brakes gave out on me at around 12k.
Our brakes suck. Switch to hawks. Should get alot more life out of them.
Old Sep 12, 2004 | 03:09 PM
Shift_Daytona Z's Avatar
Shift_Daytona Z
Brakes are not covered under warranty. They are a wear item just as the clutch is
Old Sep 12, 2004 | 04:31 PM
Strife350z's Avatar
Strife350z
yea your brake life is very normal
just make sure you get some hawks or other low dust replacements... you'll be glad you did when it comes time to wash your car
Old Sep 13, 2004 | 05:56 AM
moog's Avatar
moog
The non Brembo equipped G35's have brakes covered under warranty for 3/36k.
