HKS hipermax LS+ for 350Z
Old Oct 13, 2004 | 04:20 AM
Zivman's Avatar
Zivman
Default HKS hipermax LS+ for 350Z
Is 80080-AN002 the correct part number for this LS+ coilovers for the 350Z?
Old Oct 13, 2004 | 06:04 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
80080AN003
is what i have...
height adjustable and damping adjustable...
these will give you a very soft cushy ride...
hipermax II is what you want if you want a sport feel..
Old Oct 13, 2004 | 08:09 PM
Zivman's Avatar
Zivman
Originally posted by Jason@Performance
80080AN003
is what i have...
I wouldn't say I want a soft cushy ride, just a bit more forgiving now that I have gone to a 35 tire. The spring rates on the LS+ are Front: 10kgf/mm, Rear: 7kgf/mm. Comparing those rates to the Tein CS coilovers at Front: 7kgf/mm, 391lbs/in; Rear: 7kgf/mm, 391lbs/in and the Cusco Zero-2s at Front: 10kgf/mm; Rear: 7kgf/mm, I think I will still have plenty of sport feel for my taste, though I may be wrong.
I think the hipermax II may be too harsh. Would the RS coilovers be better?
Old Oct 14, 2004 | 09:59 AM
Road Warrior's Avatar
Road Warrior
i have the ls+ and they are not cushy at all....i have mine set at about 19 out of 30 harshness and its enough to eliminate the bounciness and provide performance and comfort too. i still have stock rims and tires also (17's)....but given i could go 11 more clicks you could get a lot stiffer feel if desired. i think its a good combination of sport and comfort without going to the extreme of one or the other...basically the best of both worlds.
Old Oct 14, 2004 | 03:12 PM
Jason@Performance
Performance Nissan
RS is a little better then the Hipermax II...
My Hipermax II at the softest setting feel smoother then stock...
Old Oct 14, 2004 | 04:02 PM
Gsedan35's Avatar
Gsedan35
Default Re: HKS hipermax LS+ for 350Z
Yes, they are listed on HKS's Japaneese site. The number Jason list's is not correct, it's for the G35 version. The Z version is different in valving (actually softer ) but does not transfer as much spring stiffness to the front. Looking at the valving specs, the Hypermax II's are as aggressive as HKS says they are, more aggressive then the RS and with higher spring rates too. I'm leaning towards the Hypermax II, but I want that kind of aggressiveness.
HKS LS+ G35 Coupe (Monotube construction, adjustable dampners)
504/448 +58%front +29% (rear springs are progressive)
transfers 29% roll stiffness to the front
Side Note: Tuned more aggressively then the LS. And they are actually valved to be stiffer then the same 350Z version.
HKS LS+ 350Z (Monotube construction, adjustable dampners)
448/448 43%front +31%
transfers 12% roll stiffness to the front
Side Note: Tuned more aggressively then the LS and this 350Z application does not transfer roll stiffness to the front in the manner that the G35 version does.
HKS LS G35 (Monotube construction, non adjustable dampners)
448/336 43%front -1%
transfers 44% roll stiffness to the front
Special Note: A comfort ride system, compare to Tein CS coilover
HKS LS 350z (Monotube construction, non adjustable dampners)
Special Note: A comfort ride system, spring rates make better sense then same G35 application, compare to Tein CS
HKS II 350Z (Monotube construction, adjustable dampners)
504/504 +61%front +47%rear $1600
transfers 14% roll stiffness to the front
Special Note: sprung and valved to be HKS’s most aggressive product, it is a notch above the RS coil over on the track, compare to Tein Flex and Jic coilovers.
HKS RS (Monotube construction, adjustable dampning)
448/448 F+43% R+31%
Transfers 12% roll stiffness to the front
Special Note: “Marketed” as HKS’s track coil over with a good street ride. They are not as aggressive as the Hypermax II's in valving or spring rates.
Old Oct 14, 2004 | 04:34 PM
Zivman's Avatar
Zivman
Default Re: Re: HKS hipermax LS+ for 350Z
448/448 F+43% R+31%
All that being said, the RS and the LS+ for the Z look to be identical from the specs posted?
I did pull the part number from the Japanese HKS website, but have been unable to find the part number in anything in English.
I would have thought the LS+ would have been the same setup for the G35 and Z. Where did you pull your info from?
Old Oct 14, 2004 | 05:13 PM
Skrill's Avatar
Skrill
Ziv,
Did the diffusers work without issue w/ your oversized tires?
Did you dremmel off the excess screw?
Old Oct 14, 2004 | 05:18 PM
Zivman's Avatar
Zivman
Originally posted by Skrill
Ziv,
I left the screw as-is, as I have yet to receive the diffussers.
Performance Nissan just got them in yesterday and shipped them out today- only ordered them on 10/3
Old Oct 14, 2004 | 07:47 PM
Gsedan35's Avatar
Gsedan35
Default Re: Re: Re: HKS hipermax LS+ for 350Z
1, All that being said, the RS and the LS+ for the Z look to be identical from the specs posted?
2. I did pull the part number from the Japanese HKS website, but have been unable to find the part number in anything in English.
3. I would have thought the LS+ would have been the same setup for the G35 and Z. Where did you pull your info from?
I numbered things to make replying easier.
1. Compairing the 350Z LS+ to the RS specs I show, yes that's the way it looks. But the RS is NOT listed on HKS's Japaneese web site, so I can't see if the valving specs might be totally different. Hearing the HKS tech talk in the U.S., the RS is more aggressive. I'll believe that when I see the valving specs. I'm able to show the spring rates for the RS because I called HKS USA and convinced them to give me that info.
2. Maybe HKS does not import the 350Z LS+ into the U.S. at this time. That would explain that. I would call HKS and ask, if they don't carry it, can they get it.
3. Some companies tune both cars the same, some do not. HKS tunes the G with softer spring rates in the rear, Cusco tunes the Z that way. And other's like Tein tune both the same. What is totally surprising is to see the same coilover setup for the G35 with stiffer dampner valving, yes normally when things are done differently, it's the G that is done softer. All my info comes from the HKS site in Japan (the spec page was NOT easy to find, but it's their) and from a conversation I had with HKS USA.
Old Oct 17, 2004 | 06:22 AM
Road Warrior
call hks usa and get the part number for the 350Z LS+ coilovers...they can order it from japan through a distributor...thats how i got mine. i didn't see the part number on their site recently but they have been out a while...you just have to call them as g35 suggested.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
