Wheels Tires Wheels, Tires
10mm spacer built in studs
Old Apr 2, 2012 | 07:15 AM
cabos g35 coupe's Avatar
cabos g35 coupe
Default 10mm spacer built in studs
looking for a set of 10mm spacers with built in stud already in.. thanks shoot me a pm if have any you can sell to me
Old Apr 12, 2012 | 06:01 PM
cabos g35 coupe
Bump!!!!
Old Apr 12, 2012 | 07:13 PM
taywan's Avatar
taywan
they make 10mm's w studs? thought they only came w/ ext ones. could b wrong.
Old Apr 13, 2012 | 10:05 AM
josansg35's Avatar
josansg35
I don't think they sell 10mm spacers with extended bolts. They only make them with 25mm and up.
Old Apr 14, 2012 | 04:58 AM
taywan's Avatar
taywan
You meant they dont sell them w/ built in studs on the spacers. They do come w/ ext. studs only I believe.
Old Apr 14, 2012 | 02:06 PM
sry110's Avatar
sry110
I believe Ichiba makes spacers w/ built-in studs (i.e. "adapter-type" spacers) starting at 15mm minimum thickness. Anything lower, like 10mm, requires the OEM studs to be replaced with longer ones.
Old Apr 15, 2012 | 10:33 AM
cabos g35 coupe
Project kics makes 10mm with built in studs just looking for cheaper used set
Old Apr 16, 2012 | 08:54 AM
SA Z-boi's Avatar
SA Z-boi
I have a set of 10 mm with built in studs so they do make them. I just got a new set of rims so I may let them go
Old Apr 16, 2012 | 02:46 PM
akks350z's Avatar
akks350z
i have 10mm ichibas with extended studs, not built it but i only want $50, monroe mufflers can push out studs for you no problem, but if not i understand....
Old Apr 16, 2012 | 07:39 PM
cabos g35 coupe
Let me know send pics to throwback8922@aol.com thanks
Old Apr 16, 2012 | 07:44 PM
taywan's Avatar
taywan
I didn't know they made w built studs.
I may end up w 10mm all around if I don't get 15mm to work on the rears. Lmk if u don't let them go. Thx
