Gas Tank Location in 2005 z?
I am planning on installing a stereo to my performance edition 350z and am wondering where the gas tank is? I am planning on putting the amps in the compartment where the bose subwoofer normally is. I plan on making an amp rack and screwing it down here? Is it safe to drill here? I just don't want to put a hole in anything important.
General & DIY Moderator
If you take out the glove box, or look at the bottom of either of the left or right compartments, you'll find the fuel tank. Don't drill there b/c you will put a hole in an area that is critical. Research a few threads here and you'll find how others have installed their subwoofers.
As mentioned don't drill DOWN in that area. However the area has a suspended mounting tab that is very convenient. If you remove the glove box you'll have a template for building your amp rack on the other side.
Also,
To make the amp rack fit I may need to cut off the little brackets sticking down from the top of the compartment (as shown in the top right of 92k1500's first picture). What are they used for? Would it be a problem to get rid of them?
liqalu04
01-02-2022 12:58 PM
CFAUVEL
10-01-2015 03:20 PM
Tochigi_236
09-27-2015 03:40 PM
