Push button Start
Old Mar 16, 2006 | 05:34 AM
dark_muppet's Avatar
dark_muppet
Default Push button Start
Has anyone put a push button start into there car? If so, how'd ya do it? It seems like it'd be a pretty easy install.
Can you replace the pushbutton with any momentary push switch?
Old Mar 16, 2006 | 07:04 AM
Joeys_z's Avatar
Joeys_z
I have seen some guys use a S2000 OEM button...I think there are a couple threads around here about this, a search might help you out. Each time this was done *if I recall correctly* you still had to use the key and turn the ignition on, then press the button.
Old Mar 16, 2006 | 07:28 AM
[]V[]addog's Avatar
[]V[]addog
correct from what i have read up on.
Old Mar 16, 2006 | 09:19 AM
dark_muppet
you mean turn it to accessory power or crank it as you press? I think even in teh s2k you've got to insert the key and turn.
Yeah I would search but the search feature doesn't seem to work on my computer here at work... DoD screwin' me again.
Old Mar 16, 2006 | 09:22 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
*subscribing*
Bubble's Avatar
Bubble
-REPLICA ARMY-
you still have to put the key in.
Old Mar 16, 2006 | 09:29 AM
dark_muppet
To answer my own questions.... I found this bit:
Connect one side of your switch to ground. Connect the other side to pin #85 of the SPDT relay. Connect ignition to pin #86 of the relay. Connect 12v constant to #87. Connect the starter wire to #30.
When you push the button it will engage the relay (if the ignition is on) and send 12v to the starter.
If you splice into the starter wire you can use either normal or button to start the car. If you cut the starter wire and connect the keyside to 87a it will allow you to start the car normally when the button is not being pressed. Being that you'll never be doing both at the same time its just an extra step that isn't necessary. Also, it wouldn't hurt it at all if you did try both at the same time.
Old Mar 16, 2006 | 09:30 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Look for member "Phatmitzu". He has the S2k Start Button.
Old Mar 16, 2006 | 09:46 AM
dark_muppet
does anyone know what color the starter wire is on the ignition harness? and the Ignition wire?
Old Mar 16, 2006 | 09:51 AM
usmanasif's Avatar
usmanasif
There is a thread somewhere here with Z's wire codes.
Old Mar 16, 2006 | 10:05 AM
gringott's Avatar
gringott
I purchased the Z8 BMW starter button for this purpose. It is silver with a black button, matches the Z. Will install next week.
Old Mar 16, 2006 | 10:09 AM
VandyZ's Avatar
VandyZ
Take pics
Old Mar 16, 2006 | 10:15 AM
usmanasif's Avatar
usmanasif
For those wanting to visually compare the S2K vs Z8 buttons, look at the bottom of this linked page:
http://www.mitsubishi-fto.org/steve/lucifer/s2000.htm
Old Mar 16, 2006 | 10:17 AM
usmanasif's Avatar
usmanasif
Originally Posted by VandyZ
Take pics
That will be a big help for all.
Old Mar 16, 2006 | 10:36 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
I like the push start on the Lexus cars...
I'd change the polished ring to brushed aluminum though to match the trim.
Old Mar 16, 2006 | 10:48 AM
barthelb's Avatar
barthelb
Master
Here's the one i plan on doing.
Old Mar 16, 2006 | 11:00 AM
maxpowers's Avatar
maxpowers
If you still have to put the key in, doesn't this button just add another step?
Old Mar 16, 2006 | 11:01 AM
usmanasif's Avatar
usmanasif
Very nice! Which car is that off? I suppose that ring lights up. If so, do u know which color?
Old Mar 16, 2006 | 11:02 AM
usmanasif's Avatar
usmanasif
Yes, but a pretty damn cool step!
Old Mar 16, 2006 | 11:09 AM
Vick781's Avatar
Vick781
You lazy bastards
