Diy: Cubby door assembly/springs **pictures included
Old 03-29-2013, 10:17 PM
RedLine_ZR
RedLine_ZR's Avatar
Default Diy: Cubby door assembly/springs **pictures included
After wrapping my center console last year when reassembling everything i had difficulties knowing how the springs on the cubby doors went back on. I ended up just putting it back together randomly and when finished my door wouldnt open by itself. id have to press the button and push on the top part to open it. today i decided to take it apart and try to figure it out and after about 3 hours i finally got it! i played around with the springs forever trying to figure how they went back on.
lets say you have everything taken apart and are ready to put it back together.
**IMPORTANT:
1-THE BLACK SPRING GOES ON THE PASSENGER SIDE
2-THE GOLD SPRING GOES ON THE DRIVER SIDE
ANY QUESTIONS FEEL FREE TO ASK.
STEP 1)
PLACE THE SPRING UPSIDE DOWN WITH THE SHORTER END FACING DOWNWARD AND THE LONGER END FACING UPWARDS.
STEP 2)
HOLD DOWN THE SHORTER END SO IT REMAINS BEHIND THE PLASTIC AS SEEN IN THE PICTURE WHILE YOU PULL THE LONGER END BETWEEN THE GEARS TO THE RIGHT
STEP 3)
SLIDE TO DOOR DOWN TILL YOU ARE ABLE TO PLACE THE WASHER ALONG WITH THE SCREW IN PLACE.. MAKE SURE THE SHORTER END DOES NOT FALL OUT OF PLACE SINCE ITS A PITA. AND SLIDE THE LONGER END OF THE SPRING INTO PLACE AS SEEN IN THE SECOND PICTURE WHERE MY FINGER IS.
STEP 4)
WITH A FLATHEAD SCREWDRIVER PUSH THE SHORTER END INWARDS WHILE AT THE SAME TIME PUSHING IT TOWARDS THE LONGER END AND CLIPPING IT IN PLACE BEHIND THE SMALL SCREW. YOU SHOULD HEAR IT CLICK IN PLACE.
STEP 5)
THIS IS WHAT IT SHOULD LOOK LIKE WHEN COMPLETED
AND THE OTHER SIDE AS WELL
The following 3 users liked this post by RedLine_ZR:
cortejor0 (03-29-2022), lifekenophobic (11-04-2022), Mykal.661 (02-06-2022)
Old 03-30-2013, 07:55 AM
nofrey
nofrey's Avatar
Nice write up bro.
Old 09-21-2013, 01:16 PM
Motowntom
Motowntom's Avatar
Thank you! Thank you! Thank you!
Old 01-17-2014, 07:37 PM
sushi1111
sushi1111's Avatar
thank you for this!
Old 09-24-2019, 02:52 PM
Louis Purcell
Louis Purcell's Avatar
Why can’t I see the pictures
Old 07-24-2020, 03:13 AM
Honza Vilimec
Honza Vilimec's Avatar
**IMPORTANT:
STEP 1)
STEP 2)
STEP 3)
STEP 4)
STEP 5)
duuuude!! Thank you veru much! Saved my ***
Old 03-29-2022, 06:45 AM
cortejor0
cortejor0's Avatar
Thank You so much for this! Really helped me put things together after I encountered the same problem. I painted the center counsel since it scratched easily.
Old 11-04-2022, 12:23 PM
lifekenophobic
lifekenophobic's Avatar
@RedLine_ZR , another thanks for this great thread! Was exactly what I needed after trying to reassemble the door and couldn't quite remember how the spring went.
sales@czp
09-23-2019 03:30 PM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
Quick Reply: Diy: Cubby door assembly/springs **pictures included
