Rear wheel bearing fails repeatedly.
Old 10-09-2015, 03:14 PM
stascom
stascom's Avatar
Default Rear wheel bearing fails repeatedly.
I replaced both rear wheel bearings at about 30k miles. After 15k miles, driver side bearing became wobbly. I swapped it again. Now, 10k miles later, my wheel has play, same symptoms as before.
What would cause premature bearing failure?
Old 10-09-2015, 03:37 PM
guitman32
guitman32's Avatar
Assuming you are pressing them on the hub correctly and using a quality bearing, ts your axle nut/halfshalft coming loose. You need to 1)clean the splines on the halfshaft to make sure its seats all the way 2)make sure the threads and nut are completely dry, and finally 3)torque the axle nut to the max spec preferably with an impact followed with a wrench to verify torque.
It would be quite difficult to over-torque that particular nut
Old 10-09-2015, 04:29 PM
HRMoneyPit
HRMoneyPit's Avatar
What offset are you running?
Old 10-09-2015, 04:54 PM
dcains
dcains's Avatar
And, where are you getting the bearings?
Old 10-09-2015, 04:55 PM
PP08HR
PP08HR's Avatar
I might add if you're installing aftermarket bearings they won't have the same lifespan as a factory...
For the most part.
Old 10-09-2015, 06:52 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
One point to emphasize: torque the 32 mm axle nut to 156 ft/lbs and check it to make sure it stays tight. I've used blue Loctite on mine (along with the cotter pin) to ensure it stays tight.
Old 10-09-2015, 08:54 PM
stascom
stascom's Avatar
Stock wheels.
Thank you. It appears to be the bearing this time
I do torque it down. I think I did 160lbs last time.
Last one I got was from rockauto. Don't remember the brand, it it was Japanese made. What do you recommend?
Old 10-09-2015, 10:58 PM
HRMoneyPit
HRMoneyPit's Avatar
OEM Nissan.
Old 10-10-2015, 07:01 AM
i-break-things
i-break-things's Avatar
Timken BM500006 Bearing Module on Amazon for $50.
Old 10-10-2015, 04:19 PM
stascom
stascom's Avatar
Looks like they make the Nissan OEM bearing. Is that correct?
Old 10-10-2015, 08:45 PM
0jiggy0
0jiggy0's Avatar
Probably, they make most oem.
Old 10-10-2015, 08:48 PM
0jiggy0
0jiggy0's Avatar
With loctite, if that thing needs to come off in 5 years it is going to be a nightmare.
Old 10-11-2015, 04:11 PM
guitman32
guitman32's Avatar
I have read this all over the internet, but with my own eyes only seen NTN stamped on OEM bearings I removed. Seen SKF on other bearings like the pinion and diff bearings. Though for replacements I have used Timken for front and rear with decent results.
Old 10-18-2015, 05:25 PM
nissanZdriver
nissanZdriver's Avatar
This. First time I found the rear passenger hub loose and found the nut was not tight. A few months ago i found both rear wheels had alittle play in them. I started searching how to replace the bearings and almost ordered oem ones.
But before I did I check both 32mm nuts. I used a impact gun first then a breaker bar with a pipe on it. Never had noise or issues since.
Tomci08
Exterior
10-12-2015 06:58 PM
Ironnipple
10-11-2015 03:07 AM
BIGPOPPAPUMP
10-08-2015 11:59 PM
07ZEKE
NISMO 370Z
10-06-2015 06:14 PM
Quick Reply: Rear wheel bearing fails repeatedly.
