FS: ZSpeed Performance Tilton Racing Premium Clutch Master Upgrade!
Old 11-18-2015, 10:07 AM
ZSpeedPerformance
Vendor - Former Vendor
ZSpeedPerformance's Avatar
Default ZSpeed Performance Tilton Racing Premium Clutch Master Upgrade!
ZSpeed Performance Clutch Master Cylinder Upgrade
Tilton Racing Clutch Master Cylinder Upgrade!
This upgrade kit uses a High Quality Tilton Racing Master Cylinder
This is a direct fit replacement, no modifications are needed to install.
The OEM Nissan 350Z Clutch Master Cylinder is known to fail over time causing a mushy feel in the pedal or a pedal that will not return on its own and stay stuck on the floor.
Fits All Nissan 350Z
03-06 G35 VQ35DE Sedans (Does not fit 07-08 Sedans)
2003-2007 G35 Coupes
We recommend the .625" kit for all DE models
.700" kit is recommended for HR model 350Z Only, If you have a very high clutch release point on your HR and would like it a little lower you can use the .625" kit.
This will cure the pedal drop issue these cars are know for esp when upgrading to a aftermarket clutch and also makes the system much easier to bleed due to its higher quality design.
Comes complete with Black PVC Coated braided stainless steel hose assy.
Professional installation recommended, Proper clutch pedal/master cylinder rod adjustment is required after installation.
ZSpeedPerformance is offline
Old 12-10-2015, 11:08 AM
ZSpeedPerformance
Bump!
Old 12-29-2015, 06:04 AM
ZSpeedPerformance
Bump!
Old 01-05-2016, 07:39 AM
ZSpeedPerformance
Bump!
Old 02-22-2016, 08:48 AM
ZSpeedPerformance
Bump!
Old 06-02-2016, 07:48 AM
ZSpeedPerformance
Bump!
Old 06-02-2016, 07:52 AM
travlee
Master
travlee's Avatar
Received 9,059 Likes on 6,523 Posts
hey Joe, you might be able to answer this users question
https://my350z.com/forum/vq35hr/6112...ch-master.html
travlee is offline
Old 06-04-2016, 04:46 PM
Infamous_Z
Infamous_Z's Avatar
Pm me .700 kit for HR shipped to 60452. I already have your CSC kit and starting to have the drop pedal issue . I have a Stage 02 Comp. clutch FYI.
Infamous_Z is offline
Old 06-28-2016, 08:55 AM
ZSpeedPerformance
Thanks for the order! Bump!
Destroyeron
12-12-2015 06:24 PM
George's350z
10-22-2015 03:19 AM
bneumann
10-20-2015 09:50 AM
EnjukuRacing
Body Interior
10-20-2015 06:28 AM
Quick Reply: FS: ZSpeed Performance Tilton Racing Premium Clutch Master Upgrade!
