Less weight = more power; Have you lightened your Z?
Old 10-08-2005, 11:28 AM
  #261
Rickdogg
Out of hiatus
Rickdogg's Avatar
Thumbs up
I placed an order for the CF pieces that replace the oem headlights and will also be installing a pair of cf doors next Friday and will not use any side glass or anything for that matter I am sure that it will save atleast 160lbs combined
Last time I weighed in at 3049 with
-Roll bar
-14" Brakes
-Nitrous system
-GT Spec Strut Bar
-Invidia Exhaust
-Front Engine Cover
-1/2 tank of gas
-OEM doors
-OEM HEadlights
-Window washer fluid reservoir in place (with no fluid)
-Speakers and radio in place
Next time I weigh in:
-Full Cage (with rear OEM strut bar cut out and rear metal area removed)
-No Nitrous System
-ARC Titanium Strut bar
-JIC Full ti Exhaust
-Removed front engine cover
-1/2 tank of gas
- CF Doors without glass or anything
-350 evo cf headlights
-Lexan front windshield
-Drilled out front bumper reinforcement
-Window washer fluid reservoir removed
-Nismo air bag resistors removed
-Radio and speakers removed
-AC Removed
I'm shooting for 2700-2750 lbs with 1/2 tank maybe less if I find other ways to shave weight in the interior.
Old 10-08-2005, 11:44 AM
  #262
dnguyent
dnguyent's Avatar
Last time I weighed in at 3069 with
-Roll bar
-14" Brakes
-Nitrous system
-GT Spec Strut Bar
-Invidia Exhaust
-Front Engine Cover
-1/2 tank of gas
-OEM doors
-OEM HEadlights
-No Nitrous System
-1/2 tank of gas
That's just nutty!
I look forward to your next weigh-in.
Old 10-08-2005, 11:57 AM
  #263
Rickdogg
Out of hiatus
Rickdogg's Avatar
Originally Posted by dnguyent
That's just nutty!
Hehe, just made a few more edits It was 3049 and I forgot that I have since then removed a few more things (ie radio and speakers )
Old 10-08-2005, 12:27 PM
  #264
gatti-man
gatti-man's Avatar
rick is this your daily driver? I mean how could it be???
Old 10-08-2005, 12:28 PM
  #265
Rickdogg
Out of hiatus
Rickdogg's Avatar
After this makeover driving it on the street everyday will go out the window. I will still drive it to work on fridays since I can see my car from my office
Old 10-09-2005, 09:54 PM
  #266
Chebosto
Chebosto's Avatar
rick- make sure they at least use vacuum bagging for your doors!!!
also. have the side impact beams come out more.. to give u more protection...
Old 10-09-2005, 11:43 PM
  #267
dmoffitt
dmoffitt's Avatar
...other ways to shave weight in the interior.
I have been thinking about doing exactly that, what do you figure it will weight / can you weigh the removed sheet metal? does your cage replace the functionality of the rear brace, and the bracing effect that the part over where a g35's rear seats live currently provides aka do you have cross/tie bars there now? pics???
i want a lighter car.... my other car, an 86 951 is all of ~2450 with everything but driver...
Old 10-10-2005, 12:22 AM
  #268
Rickdogg
Out of hiatus
Rickdogg's Avatar
I will definitely try to have it weighed when it is done. Of course I will make sure that the cage functions up to par, but more than likely better than the oem strut brace The metal area that you are asking of will be removed and of course I will incorporate this with the cage as well It is in development, so this is not complete yet.
Old 10-10-2005, 12:28 AM
  #269
Rickdogg
Out of hiatus
Rickdogg's Avatar
Yeah, these are actually vacuum bagged. I looked very closely in the back
Yeah, since there is not going to be any glass or door panel I am having the roll cage go into the doors to also give me more cockpit room
Old 10-10-2005, 09:50 AM
  #270
gatti-man
gatti-man's Avatar
dang rick. May every modder aspire to be as crazy/enthusiastic as you
Old 10-14-2005, 11:32 PM
  #271
Rickdogg
Out of hiatus
Rickdogg's Avatar
Here is stage 1
https://my350z.com/forum/questionable-posts/147963-updated-pics-of-cf-doors-and-a-weight-savings-of-140lbs.html
Old 10-15-2005, 12:52 AM
  #272
Acree
Acree's Avatar
this thread is very informative. i'm going to the dragstrip tomorrow night, and for the occassion i took out my spare tire and tools. should i take out the passenger seat? think it will make that much difference? also, i want to get weighed with me and gas in the car, where can i do this?
Old 10-15-2005, 01:51 AM
  #273
Rickdogg
Out of hiatus
Rickdogg's Avatar
Typically any weightloss will help, but if it is pretty extreme you have to get the car corner balanced each time to make sure the weight is distributed evenly. Ask around and a performance shop should be able to suggest a place. Usually it is at places that do race alignments, unlike your Discount Tire etc
Old 10-15-2005, 06:22 AM
  #274
D350Z10
D350Z10's Avatar
Coilovers help big time... save close to 100 lbs, my buddy had a 35th auto, he got the tein coilovers and weighed around 3150!! he also took out spare tire and other minor things.
Old 10-15-2005, 01:16 PM
  #275
ALong
ALong's Avatar
Rickdogg,
I wouldnt suggest cutting out the rear strut tower brace when you install the cage for several reasons.
First, the car will be stiffer if you leave it and connect the cage down tubes into it. This is what we did on my rollcage, it is also what has been done on all the GrandAm Cup Cars, the Japanese Super Taikyu cars (Go to the C-West website and check out the pictures of their Super Taikyu Cars) and on the Japanese Super GT300 cars. You can also run a triangle shaped reinforcement from the spare wheel well up to the bottom of the Strut Bar
Second, the stiffeness you give up by removing it, will not be offset by the weight. That beam wont weight alot. The sheet metal on the car is actually very thin. We cut out the inner door sheet metal on my racecar (which is the same thickness) and we reduced the weight only a couple of pounds per door. I would guess that the whole strut bar assembly, if cut out, wont weight more than 10-15 pounds, however you are giving up a huge ammount of structural stiffness.
Old 10-15-2005, 09:43 PM
  #276
Rickdogg
Out of hiatus
Rickdogg's Avatar
Originally Posted by ALong
Rickdogg,
Thanks for the information. I will pass this information on to the cage builder Thanks again!
Old 10-15-2005, 11:16 PM
  #277
sentry65
the burninator
sentry65's Avatar
I dunno, I thought the stock coilovers were pretty light as is. If anything I think my Zeal coilovers are slightly heavier than stock. Am I wrong? I suppose I can weigh my stock 03 coilovers
Old 10-17-2005, 02:45 PM
  #278
Nismo 350z
Nismo 350z's Avatar
The only weight reduction I have done was exhaust headers HFC's and rims. I might take out the spare and jack but thats all.
Old 10-18-2005, 07:31 PM
  #279
knight_white99
knight_white99's Avatar
subscribing...
Remove your headliner and visors will save more than a few pounds, and drain or remove your washer reservior (only recommended if your car is now a track car).
Old 10-18-2005, 09:58 PM
  #280
dmoffitt
dmoffitt's Avatar
rick I just wanted to remind you how much I despise you. Every time I listen to my audio system, as much as I love it, I get a twinge of guilt and think "hmm, guttted carbon doors, Nascar bars and 800-1000lb springs aren't THAT far off of a street car, right?" - worst part is my girlfriend APPROVES?!?@?#!?@# DAMN IT AREN'T THEY SUPPOSED TO TALK US OUT OF THIS ****?!!
Quick Reply: Less weight = more power; Have you lightened your Z?
