Bad to have clutch in all the time?
Old 08-29-2012, 07:16 PM
Shawz1102
Shawz1102's Avatar
Default Bad to have clutch in all the time?
I just heard that i could burn my clutch if i keep my foot on the clutch while in gear at a stoplight? I do that all the time to avoid hearing the noise from the tranny.
Old 08-29-2012, 07:22 PM
Nismo44512
Nismo44512's Avatar
I do the same thing, It gets annoying hearing that rattling all the time. Not sure if its too bad for the clutch or not tho... How many miles are on your clutch? Is it the stock one?
Old 08-29-2012, 07:36 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
As long as its pressed all the way in, no problem.
Old 08-29-2012, 10:46 PM
winchman
winchman's Avatar
Embrace the noise. It's the price you pay for not getting the super nice bullet proof 5AT.
Old 08-29-2012, 10:49 PM
Corpse11
Corpse11's Avatar
if its pushed all the way down and fully disengaged, you won't burn up anything.
Old 08-30-2012, 12:05 AM
BrickyardZ2003
BrickyardZ2003's Avatar
It states in the owner's manual of your car to not hold the clutch pedal down for periods of time such as stoplights. Also, IIRC, throwout bearings can be worn down quicker when keeping the clutch disengaged for lengths of time.
Old 08-30-2012, 12:21 AM
pattimang
pattimang's Avatar
Old 08-30-2012, 12:24 AM
Rex08Z
Rex08Z's Avatar
Not sure if this will help OP but I'm training myself to only use the clutch when absolutely necessary. I've learned to take slow turns and drive in traffic without using the clutch, just by watching the rpms so I don't stall. While this is one measure to protect your transmission, the only reason I really do it is because I was tired of jerking back and forth. I never catch myself riding the clutch at stops.
Old 08-30-2012, 02:32 AM
KingBaby
Hardest Setting
KingBaby's Avatar
Old 08-30-2012, 02:58 AM
bgant3
bgant3's Avatar
ive embraced the noise from my 6mt. I dont press in the clutch at stoplights. Sound Was annoying when i first got the car 3yrs ago, but going with the flow now.
Old 08-30-2012, 05:10 AM
Syner
Syner's Avatar
LOL hearing the lifters yet?
Old 08-30-2012, 05:29 AM
PerfZ
PerfZ's Avatar
I've never left the clutch pressed in while at lights, or even in traffic jams. Maybe I am just old school but I do recall that it can wear out the throwout bearing. I've got 123,000 on my original clutch so it works for me.
Old 08-30-2012, 05:42 AM
Bret86944
Bret86944's Avatar
If it's in all the way, nothing is rubbing so nothing will burn up. Holding it down all the way for long periods of time can wear it out faster though. Every time you press the clutch, you are bending the little metal pieces that act is a spring. The more you push on them, the faster you wear them out. This is a long term thing though, since a clutch is designed to be pressed thousands and thousands of times.
Old 08-30-2012, 07:15 AM
AngelsVQ
AngelsVQ's Avatar
No one is mentioning the strain on cmc and smc.
Old 08-30-2012, 07:31 AM
redline06
redline06's Avatar
im just gonna stop using mine lol
Old 08-30-2012, 07:37 AM
djamps
djamps's Avatar
It's best practice to not hold the clutch in more than 10 seconds. If you need it out of gear for longer put it in nuetral. Long periods of clutch-in will wear the throwout bearing and springs.
Old 08-30-2012, 10:53 AM
hellman_x
hellman_x's Avatar
Lol, this is a joke right?
Old 08-30-2012, 02:08 PM
ZSpeedPerformance
Vendor - Former Vendor
ZSpeedPerformance's Avatar
Noise? I have no noise in mine... Good fluid and a Good flywheel and it's quiet
Only thing you will do by holding it is wear the Release bearing quicker and possibly wear the thrust main bearings more than normal.
Old 08-30-2012, 03:31 PM
VMRWheels
VMRWheels's Avatar
I don't think it will hurt a whole lot but I've never met anyone that's ever done this either.
Old 08-30-2012, 05:23 PM
saywat?
saywat?'s Avatar
ur left leg must be hella tight by now
11-09-2020 10:27 AM
sherm
04-11-2020 05:21 PM
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: Bad to have clutch in all the time?
