Gearchange not as smooth after new clutch
Old 07-24-2016, 06:17 PM
Steve Mack
Steve Mack's Avatar
Question Gearchange not as smooth after new clutch
Just wondering if the gear change in mine which is not as silky smooth as it was, could have anything to do with the new exedy DM flywheel clutch I just had replaced?
I've barely done 100kms on new clutch yet, so hoping it settles in to how lovely it was beforehand...
- Or is it possible the mechanic I used didn't quite do something correct?
Old 07-24-2016, 07:12 PM
Conway_160
Conway_160's Avatar
Did you realign the shifter when you put it all back together or just bolt it back in like I did?
Old 07-24-2016, 09:13 PM
Steve Mack
Steve Mack's Avatar
...I did neither; I PAID a guy to do the whole job.
Sounds a possibility?
Old 07-24-2016, 09:33 PM
Steve Mack
Steve Mack's Avatar
...Just looked up the shifter re-alignment post;
Phew; doesn't sound too difficult then...Plus alternative posts (MANY replies to this) suggest changing oil if (as VERY common I read) 1 - 2 shift is predominantly when cold; I'll take note on next long drive of temps and if there's any change in it :-)
Old 07-25-2016, 05:47 AM
Conway_160
Conway_160's Avatar
First realign your shifter to see if that makes a difference, then fluid.
Old 07-25-2016, 03:59 PM
Steve Mack
Steve Mack's Avatar
I (or HE really should do it!) will realign the shifter as above - I'm pretty sure that's the problem.
I'll also check the oil viscosity he used.
Cheers
One question; suggestion for 'adhesive' the guide says to use for gear ****?
Obviously something that won't stop it ever coming off again! LOL
Old 07-25-2016, 04:06 PM
SmoothZ
Senior Super Moderator
SmoothZ's Avatar
Received 1,906 Likes on 1,354 Posts
Realign that shifter. Should "cure" the problem.
I've never had issues with the shift **** coming off, even when I didn't use any adhesive or glue.
Old 08-01-2016, 11:25 PM
Steve Mack
Steve Mack's Avatar
1st way I found:
https://my350z.com/forum/engine-driv...alignment.html
2nd method:
https://my350z.com/forum/exterior-an...ide-plate.html
infiniti0606
Drivetrain
07-21-2016 06:37 AM
Daserz33
07-12-2016 11:46 AM
Blacked
07-11-2016 09:21 AM
FJJeremy
07-11-2016 04:16 AM
ZSpeedPerformance
06-30-2016 06:22 AM
Quick Reply: Gearchange not as smooth after new clutch
