DIY: A/T Cooler install
Old Jun 20, 2011 | 06:07 PM
exZilaration's Avatar
exZilaration
Arrow DIY: A/T Cooler install
Ok guys I've been searching around and not a single A/T cooler install DIY so I attempted to do my first DIY on my350z. If I'm unclear in anything please let me know.
Just to clarify my Z is an 05 35th Anniversary A/T.
I decided to use the suggested routing which is Tranny< A/T radiator< Cooler in< Cooler out < Tranny Return
Products required
Automatic transmission cooler
Brackets and hoses (usually provided with the cooler)
Hose clamps
Quart of Nissan Matic J fluid or Matic S fluid
Tools needed:
3/8' ratchet w/ socket set (Particularly 10mm and 12mm deep socket)
Various extensions
Flat head and Phillips screwdrivers
Drill w/ 11/16ths drill bit
6 pack of Heineken (optional)
I got my cooler from B&M
1) Remove front bumper and drop your undertray. Use a 10mm socket w/wrench
2) Now, how you mount your cooler is purely up to you. I'm not boosted so no intercooler in my way. I used the factory holes from our impact cross bar mount.
3). I used an 11/16ths drill bit to drill 2 holes in the brackets in order to fit this on the mount. This is how it should look mounted.
4) This is how it should look from far. (Dont mind the top bracket just experimenting)
5) Next, mount the other side bracket for more support. I used the bolt from the hood latch which is a 12mm.
6) Lastly I used the supplied zip tie to secure the lower left corner of the cooler.
Finshed mounted Cooler
7) In order to snake the lines from the factory radiator to the cooler and then back to the tranny, you'll need to shave some of the cushion on the left side of the undertray.
THIS IS FAR AS I GOT I WILL CONTINUE THIS WEEKEND SO STAY TUNED GUYS AND SOME FEEDBACK WOULD BE GOOD. AIGHT!
Old Jul 6, 2011 | 09:07 PM
g35thrilla's Avatar
g35thrilla
hey man im thinking about this diy cause im going to be purchasing a trango kit here pretty soon. do you have pics of the underside of the car so i can see exactly how the hose routing went.
plz and thanks
Old Jul 6, 2011 | 09:29 PM
lgear080's Avatar
lgear080
I've seen this mounted at the rear... doesn't that make more sense in terms
of hose length and such?
Old Oct 18, 2011 | 02:18 PM
AuAltima3.5's Avatar
AuAltima3.5
For AT cars, routing to the front uses the least amount of hose. It is tricky to accomplish since you must make sure bend radii are not 'exceeded'.
AT cars use the radiator to cool/heat fluid hence the front side install. I considered rear mount on my G but it alot of line to run and I worried about line pressure loss for such a long run. You also need an aftermarket exhaust (dual muffler style) to make rear mount coolers work.
Old Oct 18, 2011 | 02:38 PM
SDGenius's Avatar
SDGenius
pretty sure you're thinking of a differential cooler
Old Oct 25, 2011 | 07:20 PM
Bmurray350z's Avatar
Bmurray350z
really thinking about doing this..
Old Nov 1, 2011 | 05:55 PM
dvsone's Avatar
dvsone
Is this mostly for 350's on the track or longevity of the transmission? Sorry I lack knowledge when it comes to the transmission department :/
Old Dec 29, 2011 | 06:37 PM
blAk mAx's Avatar
blAk mAx
top
Old Aug 17, 2012 | 03:03 PM
g35thrilla's Avatar
g35thrilla
what size of tranny hose did you use???
apex locator
Jul 23, 2021 02:27 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
