Engine Swaps For all your engine swap experiences, ideas, questions, & more..
2jz 350z
Old 08-26-2015, 11:41 AM
  #61
Highway Riding
Highway Riding's Avatar
GL... I recently just had a shop finish up my 2j sc single turbo build as I needed alot of custom welding. Sometimes it is best to let the pros take over if $$ allows! GL
Old 08-26-2015, 08:35 PM
  #62
Resmarted
Resmarted's Avatar
Originally Posted by IanP
So this arrived at my house today
figured I may aswell have a bit of a tidy up. this is just some of the stuff that came out of the car
decided to chuck the front bumper on just because (I'm still sorting through bags of bolts trying to find everything hence why its not "fitted"!
Test fitted my spark plug cover
Chucked a seat in to free up some garage space
Custom prop shaft
Defi gauge in the door vent
Battery relocation. Still need to buy a smaller battery
Custom power steering tank hidden away, catch can to also be mounted here
So now comes the dilemma.
I've been in discussions with another garage to finish it off for me but it wont be until later this year/early next year. If I do go ahead with it then I will be making a few changes to the spec of the car.
Depending on the outcome of the cost discussion then I may still end up breaking it.
Either way, its home with me now and I can take my time to decide what I'm doing
Nice car! What turbo? t4 journal bearing...?
Old 08-28-2015, 02:28 AM
  #63
IanP
IanP's Avatar
Turbo is a Borg Warner S366 but will likely be swapped out for a Precision 6266
Old 08-31-2015, 01:54 AM
  #64
Tochigi_236
Tochigi_236's Avatar
Subbed FTW!
Old 08-31-2015, 02:39 AM
  #65
IanP
IanP's Avatar
I wouldnt get too excited over it
The car is being broken at the moment, after 14 months I'm fed up of it and refuse to put any more cash into it
Old 08-31-2015, 03:06 AM
  #66
NOLAGG
NOLAGG's Avatar
But why, what else is needed?
Old 08-31-2015, 03:09 AM
  #67
IanP
IanP's Avatar
List of what needs doing. This is just from what I have discovered myself in the last few days
Replace rear brake pipes
Install Thermostat (May already be done)
Install pulleys
Install oil filter assembly
setup cams
install water pipe neck
make LHS intercooler pipes
plastic weld front slam panel due to damage
repair FMIC brackets
Make a battery box/brackets behind passenger seat
finish running wires for battery relocation
finish fuel pump install
install fuel filter
purchase and run fuel lines for return system
finish power steering lines
install starter motor
install power steering pump
install tensioner pulley
install oil cooler
install clutch
install flywheel
install crank pulley
install wiring harness
figure out which sensors are required for inlet manifold and purchase
figure out which sensors are required for throttle body and purchase
install vaccuum hoses
finish heater pipe setup
install chassis brace
install front lower arm bar
install rear lower arm bar
install water temp sensor
install oil temp sensor
install oil pressure sensor
install oil catch can
make and install a radiator over flow tank
fabricate a custom decat/downpipe
install custom prop shaft
relocate gear shifter
install oil lines for turbo
install water lines for turbo
Install Accesory belt
finish front brake line install
Fabricate throttle cable bracket and get working with DBW throttle
purchase and install spark plugs
roll rear arches
purchase 4 new tyres
sort alignment
purchase and install welded crank sprocket
Purchase and install electric fans
bypass AC
This is after 14 months & roughly $45K I just dont have the money to keep dumping into it.
Old 08-31-2015, 09:29 PM
  #68
midz350
midz350's Avatar
Reason?
The BWS366 will make more power than the 6266 and is a heavy duty turbo that built to withstand ~90 PSI on diesel engines.
The Precision turbos are prone to blow the seals. Look up "precision turbo reliability"
If you want a faster spool you can go with a SP QSV or a Treadstone Cast manifold or even both.
Classy (09-01-2015)
Old 09-01-2015, 05:12 AM
  #69
jdm-v35
jdm-v35's Avatar
I hope you get to finish it. this is such a proper build and I'd hate to see you bail on it.
Old 09-01-2015, 07:40 AM
  #70
IanP
IanP's Avatar
Too late, A lot of it has already been stripped and sold
Old 09-01-2015, 07:47 AM
  #71
NOLAGG
NOLAGG's Avatar
I'm willing to buy parts pm me what's for sale please.
Old 11-05-2015, 08:39 PM
  #72
venture210
venture210's Avatar
Whyyy! Seeing some one give up on a legendary build because of the remaining costs and work really bums me out. I know I'm about 2 months late on this thread but gaaah. Very few z owner will ever be able to pull off a swap like this.
Old 11-06-2015, 05:53 AM
  #73
graffkid732
graffkid732's Avatar
It's unfortunate you had to or decided to part out : /
Old 11-09-2015, 09:20 AM
  #74
IanP
IanP's Avatar
I was near enough $50K into it and the engine had never been fired and there was still a load of work to do.
Unfortunatley I lost a few friends over the build but I am a lot happier now that I'm not spending all my time, energy and money on the build - My GF is a lot happier too
Its not all bad though, I've been able to do loads of things with the money that I raised by parting it out
I bought a new daily
and a new toy
and have a stack of cash left to put towards buying a house next year
Old 11-09-2015, 02:28 PM
  #75
Resmarted
Resmarted's Avatar
and a new toy
I can't blame you. Hardcore builds take a lot more out of you than people realize. It can be hard to balance life and a money pit build. Spend too much time on the car and you're behind in all sorts of other fields. Too much money; even worse. Live your life and you just have a pile of cash burning away in your garage.
Old 11-09-2015, 03:21 PM
  #76
Quamen
Quamen's Avatar
Shame to see this build not come to completion but I understand. My LS1 swapped Z was $80,000 all in when said and done including the purchase of the car.
Hope you like the new toys thought!
Old 11-11-2015, 05:18 AM
  #77
jdm-v35
jdm-v35's Avatar
Seems like you made a good choice. I would take either of those cars over my G any day. And a house is way more important than a car.
liqalu04
01-02-2022 12:58 PM
Dsowe
02-17-2021 10:38 AM
issyz
07-02-2017 03:04 PM
nanotech
10-02-2015 05:02 AM
samansharif
09-25-2015 12:31 PM
Quick Reply: 2jz 350z
