(OEM) FS: Complete Engine Part-Out - 2004 DE 100k miles
Hey guys - I came across a DE engine from an LS guy that he swap out of his friend's z. The engine has approximately 100k miles and was replaced due to a thrown rod through the oil pan. From my initial tear down the top end looks to be unaffected – Although I am still tearing into the block.
If you are looking for any particular part that is not listed please let me know and I will get you details. I can ship just about anywhere. I will update the thread as parts are sold. All prices are negotiable. Below are pictures and prices/status of available parts. I will update the list as things are sold.
You can PM me or you can shoot me a txt msg at (seven one nine) three six nine - eight eight nine zero.
Valve/Springs – Pending
Headers – $100 Sold
Intake Manifold – $60 Sold
Knock Sensor & Harness – $20 Sold
Upper/Lower Plenum - $100 Sold
Crank Shaft - $200
Engine Block – $160 - damaged / not for sale
Heads w/cams -$225
Head Covers - $150
Throttle Body - $80
5each pistons/rods - $100
Injectors/Fuel Rail - $40 Sold
Crank Pulley - $25
Belt Tensioner - $15
Timing Chain Assembly - $100
Intake Cam Gears - $40 Sold
Water Pump - $15
Oil Pump - $15
Ignition Coils & Harness- $60
Thermostat - $10
Camshaft Position Sensors(2 each) - $20 Sold
Camshaft Solenoids - $60 Sold
Coolant Pipes (3each) - $20
Engine Wire Harness – $80 Sold
Engine Mounts - $10
Headers – $100 Sold
Crank Shaft - $200
Heads w/cams -$225
Head Covers - $150
Throttle Body - $80
Crank Pulley - $25
Water Pump - $15
Oil Pump - $15
Thermostat - $10
Engine Mounts - $10
looks like they go for anywhere from $60 - $100 on ebay - is $50 + $20 shipping fair for the cover?
Assuming were talking about the same 'upper oil pan'
http://www.courtesyparts.com/11110-o...4_715_716_719&
... it is blitzed...
yeah - it's hard to tell from the pictures but all the teeth are present and in good condition. No broken or excessively worn teeth. There is a pin on the front face and that pin is missing from one of the gears. I have all the other timing chain parts so if there is anything else you need let me know.
Exhaust & Intake gears pictures:
upper oil pan is blitzed...
Weekend Bump - if you need engine related parts please let me know!
liqalu04
01-02-2022 12:58 PM
