Sponsored by:
Sponsored by:
Easy fix for hazy or cloudy instrument gauge cluster
Old 04-02-2016, 08:14 PM
ottoman808
ottoman808's Avatar
Default Easy fix for hazy or cloudy instrument gauge cluster
So I had to share this info as it worked amazing and I figured I'm not the only one that is experiencing this.
My gauge cluster was cloudy and hazy where you see the mph, tire pressure etc. And I couldn't get it to clear up with any products.
I bought CRC 2-26 from home Depot for like $4 and sprayed it on a microfiber towel and wiped it on the lense, it cleared right up and looks like new!
You all should try it if you have any cloudy or hazy Gauge clusters!
Old 04-02-2016, 08:38 PM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
Welcome, thanks for the tip.
Old 04-02-2016, 10:24 PM
HRMoneyPit
HRMoneyPit's Avatar
You made an account for this?
Old 04-03-2016, 11:41 AM
ottoman808
ottoman808's Avatar
I made an account because I just got a 350z recently. But I made this post because I haven't seen anyone address a solution for this issue on here. I read it on maxima forums which was a hassle finding. Just trying to help.
The following 3 users liked this post by ottoman808:
jhc (04-03-2016), rustyschopshop (04-03-2016), Spike100 (04-04-2016)
Old 04-03-2016, 08:34 PM
rustyschopshop
rustyschopshop's Avatar
Btw welcome to the forum.
Old 04-03-2016, 09:03 PM
ottoman808
ottoman808's Avatar
Thank you
Old 04-04-2016, 05:20 AM
rancor
rancor's Avatar
Does the CRC 2-26 melt the plastic?
Old 04-04-2016, 10:00 AM
ottoman808
ottoman808's Avatar
No it doesn't, it even says on the cover that it's safe on plastic.
Old 04-04-2016, 12:22 PM
iideadeyeii
iideadeyeii's Avatar
That's not a fix. . . you're filling in the scratches with oil and basically putting a temporary clear coat on the plastic. You could rub 10w30 on it and have the same effect.
travlee (04-04-2016)
Old 04-04-2016, 12:36 PM
travlee
Master
travlee's Avatar
Received 9,056 Likes on 6,521 Posts
exactly
Old 04-04-2016, 12:40 PM
ottoman808
ottoman808's Avatar
That may be the case. I'm not sure of the science behind it but there was a fog to the lense that it got rid of. It does say this on the description which may also add more than straight up motor oil would do.
Cleans, lubricates, penetrates and loosens corrosion
Displaces moisture to prevent corrosion
Helps restore water-damaged electrical equipment
Restores resistance values and helps stop current leakage
Old 04-04-2016, 12:42 PM
travlee
Master
travlee's Avatar
i bet it comes back, and eventually gets worse..... kinda like armor all does
Old 04-04-2016, 12:59 PM
ottoman808
ottoman808's Avatar
Alright, well I'll do a follow up in a month or 2 to say how it's held up.
juicenigk
South East Marketplace
05-12-2016 12:14 PM
vqpowahhhh
Wheels Tires
04-07-2016 05:58 PM
Siqcology
03-29-2016 12:50 PM
Detailed Image
Cleaning & Detailing
03-29-2016 05:03 AM
Quick Reply: Easy fix for hazy or cloudy instrument gauge cluster
