Hood sits up too high
Simple hood alignment question
Well, my hood has a tiny gap that needs to be fixed after I got fender replacement and fender aligned. Just a hair to the side, here is my dumb question, do you loosen the bolts that attatches the hood to the hinge or the bolts that attatches the hinge to the car?
Sounds fairly dumb, but I would rather not screw this up or run in circles.
Thank you.
Thank you.
Well, to cut it short I wrecked, got new fender and etc, got fender aligned etc. I started messing with my hood (trying to align it) a bit, and now it seems to sit up too high. The gap is not necessarily big between the hood and fender it's just the hood is too high, also now I have to press harder to close the hood. I was messing with the hinge (the two bolts on hood and then the two bolts bolted directly to car)
Also, note before I was messing with hood it did not sit too high it just had a larger gap between it and the fender.
Now, it just sits too high and I am not quite sure what to do. And advice would be great. I'm sure I just did something stupid wrong. Nothing appears to be bent.
We had a similar issue, turns out it was easier to remove the bolts holding the fender and put in 1/8 spacers under the fender line to match it up, took about 30 mins.
Thank you, and do you know if it's possible to move hood over a hair? I attempted but just made the situation worse. I read online, but obviously did something wrong.
Doesn't look perfect, but I did wreck at a high speed, doubt it'll be perfect and it's not the OEM fender. Surprised it's came this far.
Here is it before any work done to it:
Thanks to everyone who has helped me here!
I just used some washers I had in garage
fender is a cheapo off ebay. Fine enough for me.. right now, after all I've had to do to car in repairs in past month or two.
