--->jkenefic version 3.0 build<---
Old Jun 4, 2008 | 03:15 PM
  #121
r0mey's Avatar
r0mey
Originally Posted by Philthy
I'm having a 'few' mods done to my EVO while I'm away on my trip, and the first thing that the big name shops (Full-Race, AMS, Buschur) strongly suggested L19 studs with the stock head gasket... The L19's are so widely used on that platform that they can be purchased for ~$200, still double the price of the standard ARps $100 - but a great value vs having to replace the headgasket down the road...
I'm glad people are testing less expensive alternatives, and more importantly providing details on the exact hardware, but call me conservative, I would still recommend at least L19's for our platform at this point.
Solid point there phil.
Old Jun 4, 2008 | 04:20 PM
  #122
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I agree with Phil that the L19's are still a worthy investment on the VQ. I'm getting the L19's and HKS gasket with my build. It's not that much more money for piece of mind IMO. Considering my power goals and intended track use... I just can't justify pinching pennies on something that is a relatively inexpensive part of the motor build to begin with.
The L19's have proven themselves on other platforms running big power and on IP's 1000+ whp Z with 8 second passes. I don't think it is time to dismiss the need for the L19 altogether.
I think the HR studs sound promising for guys on a budget who are doing a mild to moderate build under 600 whp with street driving being the primary use. And obviously, that is an overwhelming majority of the FI guys in this community. So the OP's sharing of this info is very cool, significant and applicable to a large portion of this community.
But I think the L19 is still prudent for anyone running big power or tracking their car on a regular/frequent basis.
Just my .
Old Jun 4, 2008 | 04:22 PM
  #123
MADScientist's Avatar
MADScientist
Piggy backing on what rcdash, Philthy, and Sharif are saying here...
I would like to see the clamping force provided by each bolt solution as well. I am sure that the L19 will yield the highest results when comparing OE diameter bolts/studs... I am also sure that ultimately for maximum horsepower capacity the L19 would win out.
The other platforms mentioned that use the L19 with great success have one key difference... The blocks are cast iron, not allum. Which when doing my research on TTY swayed me to try them on this build. For example, the LS1, 2,6,7 GM V8 guys are using TTY bolts in their builds up to and over 900whp. These blocks are allum like the VQ. The thing that interested me the most was how the TTY bolts displace the clamping load with changes in pressure and heat vs a conventional ARP stud.
Here is one of the articles that lead me to believe that this would work for the power levels I wanted to achieve...
http://www.tomorrowstechnician.com/A...ing_heads.aspx
and one more that is a little more involved, but helps to explain why the manufactures use TTY and may suggest why over time we see problems with other types of fasteners...
http://www.enginebuildermag.com/Arti...uetoangle.aspx
At this point I have proved the the HR bolts will hold the power. The next test is will they continue to hold the power over a extended period of time...
Old Jun 4, 2008 | 04:50 PM
  #124
JAM3Z's Avatar
JAM3Z
Phenom
I'm sorry, what is TTY?
Old Jun 4, 2008 | 05:13 PM
  #125
rcdash's Avatar
rcdash
torque to yield bolts (aka angle torque or stretch bolts)
- and after reading some of those links you posted joe, it's not just clamping force at a point in time, but the force over time, after many heat cycles that counts as well - as well as how even the clamping force is across the aluminum block. I can see how a lack of uniformity of clamping force could cause focal loss of clamping - and loss at any point is just as good as a complete failure...
Old Jun 4, 2008 | 05:51 PM
  #126
MADScientist
That is why I am wondering why a lot of the sleeved block guys don't have issues right away, it is 10,000 miles later when they have a failure...
Old Jun 4, 2008 | 09:13 PM
  #127
IIQuickSilverII's Avatar
IIQuickSilverII
there are too many factors in the failed sleeved blocks, specially over the span of 10k miles and different setup, drivers, etc.....in most cases bad machining, and also not running a proper ems, etc.
Dismissing them over a bad experience isn't the way to go, and IMO the idea that they don't work because a few thing its just going to pussify the VQ cause to even think about approaching the power levels of the 2jz, despite how great just pistons and rods alone have done, sleeves will be needed.
Old Jun 4, 2008 | 09:15 PM
  #128
JAM3Z's Avatar
JAM3Z
Phenom
there are too many factors in the failed sleeved blocks, in most cases bad machining, and also not running a proper ems, etc.
Dismissing them over a bad experience isnt the way to go, and IMo the idea that they dont work becuase a few thing its jsut going to pussify the VQ cause to even think about aproaching the powerlevels of the 2jz, despite how great jsut pistons and rods have done, sleeves will be needed.
+1, but I agree completely. But in regards to the pussyfying, I can understand in the sense that I would be apprehensive too if I was getting ready to drop that kind of coin on my motor.
Old Jun 5, 2008 | 03:47 AM
  #129
MADScientist
Do get me wrong... The use of a ARP stud on a sleeved motor is not the reason these things fail... But in combination with improper machining the problem will surface faster IMO. Improper machining of sleeves is the root cause of these failures that we have seen including my own. We can get the the all mighty 2jz power levels as soon as these shops can get the sleeving process right and most importantly reliable. The question is does high power and reliable belong in the same sentence with VQ35? lol
Old Jun 5, 2008 | 03:49 AM
  #130
MADScientist
And when I say reliable I mean on par with other platforms making 1000whp...
Old Jun 5, 2008 | 04:30 AM
  #131
DanielW's Avatar
DanielW
Between this thread and Forcefed's thread I'm getting alot of great information and ideas for my build in the future. Just wanna say thanks to you guys for taking some chances and providing us with the results.
Old Jun 5, 2008 | 04:38 AM
  #132
MADScientist
You are welcome... Someone has to do it! Looks like we drew the short straws. Next time it is someone elses turn! lol
Old Jun 5, 2008 | 04:43 AM
  #133
DanielW's Avatar
DanielW
I'll be happy to be a test mule when "my ship comes in" lol.
Seriously though, you mentioned that the HR head bolts worked with some "minor modification". Would you mind sharing what kind of modification is neccessary?
Old Jun 5, 2008 | 04:59 AM
  #134
DanielW's Avatar
DanielW
Sorry if this is a repost but didn't see it anywhere else in the thread. If it is I'll delete it. But I was searching a little on da google and came accross this diagram that helps explain how the HR headgasket is more efficient for high performance applications like FI
http://www.jimwolftechnology.com/wol...HEAD_BOLTS.pdf
Old Jun 5, 2008 | 05:05 AM
  #135
App6MT's Avatar
App6MT
Technically posted earlier but it's such a great find that it doesn't matter
Old Jun 5, 2008 | 05:10 AM
  #136
DanielW's Avatar
DanielW
DAMMAT
Old Jun 5, 2008 | 05:34 AM
  #137
merlin3's Avatar
merlin3
by looking at the pdf file and looking at the differences in the headgaskets, how does the hr head gasket get the water to and from the head? It looks like a lot of the ports are blocked off.
Old Jun 5, 2008 | 09:35 AM
  #138
rcdash's Avatar
rcdash
Well from the headgaskets posted by you and Alberto, cooling issues (or should I say localized overheating issues) seem more relevant rather than head bolt/stud selection. In that regard, you have implemented two fixes: HR headgasket and Evans coolant. I think either one would have solved the issue, but doing both doesn't hurt.
Old Jun 5, 2008 | 09:40 AM
  #139
DanielW's Avatar
DanielW
dumb question probably but where can I buy the HR headgasket besides from nissan? or is that the only place?
Old Jun 5, 2008 | 11:48 AM
  #140
IIQuickSilverII
i think it will, i hope... i had darton themselves sleeved my block, th rest of the machininc intense did it in-house
