alarm, window, and door sensor issues
Old 04-22-2015, 07:35 AM
ZaaronZ
ZaaronZ's Avatar
Default alarm, window, and door sensor issues
Hey guys, i just privately got a brickyard 2003 touring hatch for a good deal.
I plan on restoring it and modding it, but thats irrelevant right now.
My problem started a few days ago when my alarm stopped working, so i did a reset and still nothing, but it locks and unlocks.
Then i noticed the open door light in the dash stays on, so i checked all doors and hatch, and everything was fine.
Then lastly, i noticed my passenger window doesn't go up the last inch when you close it, so it leaks now
I pressed the door sensor and it doesn't do a thing on the passenger side, but the driver side works perfect.
So is it as simple as just replacing the door sensor and everything else will work properly again???
Lastly, now my gas gauge goes wonky and shows empty for about 5 minutes after startup, then the gauge slowly goes back to normal and all the warnings go off.
Im starting to think my car is grounded wrong????
Any and all productive and useful info is appreciated
Old 04-22-2015, 08:47 AM
amr_electron
amr_electron's Avatar
The gas gauge is normal to act up in this car. And for other faulty controls, I would recommend trying a BCM reset first.
Old 04-22-2015, 09:39 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
Before doing any type of reset, pull all codes off the BCM first. There may not be a CEL, but codes should be held in memory.
Old 04-22-2015, 04:52 PM
ZaaronZ
ZaaronZ's Avatar
codes for the alarm and door sensor???
Okay, i will check it out, thanks...
Old 04-25-2015, 08:22 PM
ZaaronZ
ZaaronZ's Avatar
everything started working today as normal...what the heck
Old 04-26-2015, 07:16 AM
dkmura
dkmura's Avatar
You've got some type of electrical problem- they usually come back at the worse time. Check the BCM anyway to see if there are any codes.
Old 04-26-2015, 02:28 PM
ZaaronZ
ZaaronZ's Avatar
yeah majorly.
I got up early this morning to my alarm going off, and my passenger window going up an down on its own!!!!
Old 04-26-2015, 02:41 PM
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
did you happen to check the history of the car, makes me think it has a flood title or something... maybe hurricane being in florida
sounds like you bought someone else's headache
Old 04-26-2015, 05:38 PM
ZaaronZ
ZaaronZ's Avatar
it was a clean title one owner car from a 50 year old.
It has strobe lights, and a $6000 stereo system in it with a blown double din radio that i took out, so maybe something is messed up with the grounding or system thats making everything else go crazy?
And yes it is a huge headache right now, but could be something stupid and simple, i just need to do more trouble shooting i guess.
Old 04-26-2015, 05:41 PM
travlee
Master
travlee's Avatar
electrical gremlins are a pain. good luck sir
11-09-2020 10:27 AM
sherm
04-11-2020 05:21 PM
2ndchanceZ
10-26-2015 08:03 PM
350z82
10-01-2015 06:25 PM
Quick Reply: alarm, window, and door sensor issues
