Repairing a broken 06+ headlight
General & Tech Moderator
That's a really good question. If the holes were smaller, I'd say rtv silicone. In your case I'd get some 10 mil clear plastic/polyethylene and a can of 3M spray glue. Cut to size, spray, and let it tack up real good.
Let us know how the repair goes.
I took apart the lights to clean all the dust from inside, and it was full!
One of the lights seems to have been clear coated in the past. Its peeling by the turn signal bulb and looks gaudy. 500 grit sand paper wouldnt remove it and im scared to use anything lower as it might scratch the lens too deep.
Any tips on removing it? Aircraft spray might work but will it damage the lens?
It *might* be the laquer/clear coat that someone made another thread about because under the clear I peeled off, it seems to be sanded with 1000 grit. And thats what the video calls for.
I had a similar problem recently with the clearcoat on the silver steering wheel trim. Regular acetone and a rag with some patience worked well on that. Maybe try a test spot.
