Piston recommendation for ~20psi
Old Nov 8, 2015 | 11:54 AM
goatofrafin's Avatar
goatofrafin
Question Piston recommendation for ~20psi
Hi all,
Now that I am gathering parts for my Rotrex build, I have a variety of brands for selecting low compression pistons. Considering I won't be getting past 20psi, what piston brand would you recommend? Here are some more info:
My car will not see any drag racing or drifting, just some occasional WOT runs. Moreover, a Rotrex builds boost gradually so, 20psi would be the absolute maximum at redline. Given these facts, I think that mammoth strength is not a first priority (like for instance the Arias Extreme) but things like reliability, longevity, minimal cylinder bore wear and as less incidents of defective batches as possible...
For what I know, Wiseco, CP, Cosworth and Arias are among the brands I can choose from. What is your experience?
Old Nov 8, 2015 | 01:29 PM
Conway_160's Avatar
Conway_160
Weisco stock compression.
Old Nov 8, 2015 | 02:46 PM
meanz's Avatar
meanz
Taywan has cosworth stock compression Pistons with low miles he's looking to sell.
Old Nov 8, 2015 | 02:52 PM
goatofrafin
Do you consider that 10.3:1 compression (this is stock compression if my memory serves me well) for 20psi is ok? Even when considering proper ignition tuning and safe fuel mixtures (11.0-11.5), won't detonation still be a problem?
Old Nov 8, 2015 | 03:00 PM
goatofrafin
By the way, from a quick search I found out that Cosworth is offering 8.8:1 and 11:1 compression ratio pistons. If anyone could provide me with a link with other compression ratio Cosworth piston options (besides Amazon), I would be grateful...
Old Nov 8, 2015 | 03:24 PM
Conway_160's Avatar
Conway_160
What fuel you using? That has more to do with the comprssion than anything. Im running 11:1 on 91 oct but only 11-12 psi. When I switch to E85 ill run as much boost as I can get out of the procharger.
Old Nov 8, 2015 | 03:58 PM
2bad240's Avatar
2bad240
I'm running 11:1 Pistons and making 20psi with my vortech. More about proper tuning than compression causing detonation. Go with higher compression and get better response and more power off boost or at lower rpm
Old Nov 9, 2015 | 10:13 AM
tonyzS/C03's Avatar
tonyzS/C03
This^
The other side of this equation is heat soak. If you dont plan on continuously beat on the car for long periods of time, say at a track, then you can get away with running higher compression. Another alternative is to run something such as meth to keep things cool. All up to you and what you are willing to spend and what you want to do with the car, I do agree with whats been said before though, Weisco stock compression would be a good look probably.
Old Nov 9, 2015 | 12:58 PM
rcdash's Avatar
rcdash
FWIW Dynosty recommended 8.5:1 for my build based on a requirement that I wanted to be able to run pump gas and E85. The off boost response is not that much poorer with a lower compression ratio - just a few percent less hp. I believe the difference between 8.5:1 vs 11:1 will be 5-7% difference in peak hp. Reducing potential for knock at high boost easily outweighs the small % gain in compression. Adding 1 psi of boost, gives you 5% right back... Add in 2 psi and you've exceeded whatever you would've lost with lower compression. So if you've got spare boost, I'd recommend a nice safe compression ratio.
Old Nov 10, 2015 | 08:04 PM
bealljk's Avatar
bealljk
Oil cooler!
Old Nov 11, 2015 | 06:04 AM
tonyzS/C03's Avatar
tonyzS/C03
Originally Posted by bealljk
Oil cooler!
one part of the answer...
Old Nov 11, 2015 | 08:15 PM
bealljk's Avatar
bealljk
^a step in the right direction
Old Nov 20, 2015 | 09:50 PM
OldManZ350's Avatar
OldManZ350
With Turbos that works great because boost is all in by 3500rpm or so, but with a Supercharger full boost is at redline. So stock CR or evn 11:1 works well.
Old Nov 23, 2015 | 01:49 PM
rcdash's Avatar
rcdash
^ good point
goatofrafin
Jun 17, 2019 10:42 AM
ryanjarosz63
North East Marketplace
Jan 19, 2016 07:47 AM
ogiehooker
Nov 11, 2015 02:44 PM
350z82
Drag
Nov 9, 2015 10:51 AM
DesertSleeper
Nov 5, 2015 01:07 PM
