SPC Toe Bolt install write up with pics courtesy of Protocav.
Old 04-19-2006, 10:29 AM
MIAPLAYA
MIAPLAYA's Avatar
Default SPC Toe Bolt install write up with pics courtesy of Protocav.
BTW he is more then happy to install these for you if you live in Socal
Mods can I get a sticky for this thread and a cookie for protocav?
http://turboneticsownersclub.com/tur...oltinstall.pdf
***EDIT***
SINCE LINK ABOVE IS DEAD, ADDED LINK AGAIN HERE:
http://www.batit.com/forumpics/spctoeboltinstall.pdf
ALSO, I have gotten PM's where people have dremeled the camber arm location! MAKE SURE to only SLOT and dremel the TOE LOCATION - notice that the toe location is the subframe SLOTS that are BEHIND The differential. They are the slots where the spring bucket arm attaches to the subframe lug!
-JASONZ-YA
::UPDATE:: - POST 154 - https://my350z.com/forum/9775042-post154.html
Originally Posted by manual g
The OP filed the holes at the insides. The SPC video shows the hole being filed equally on both sides.
Does the OP's method allow more toe out?
Any info would be great..thanks.
Originally Posted by annihilator3001
I am doing a install on a g35, and i am wondering the same thing, why only the inboard cut?
Originally Posted by VORTECH350
^^^ can anyone answer that question?
Originally Posted by ian99rt
The way the suspension reacts to lowering you only need to have additional toe out.
Moving the toe arm's pivot point inward creates more toe out, thus cutting only the inward side.
guys, hands down i recommend everyone elongate both sides -
I have been lazy and have not updated this on this thread, but i recommend elongating both sides and this is why:
The subframe is aluminum and the slot the toe adjust bolt fits into there due to raised sections on each side....well, those raised sections are soft aluminum.
HUMAN ERROR:
you take the z to the local alignment shop, and sit in the waiting area. IF you dont tell the alignment guy "hey, by the way, I only slotted one side" he will be WRENCHING on that toe bolt, over powering the FLAT in the eccentric and DAMAGING the RAISED section of the subframe sides.
dun, dun, dun.....crappy sliptastic alignment...
unless your there doing your own alignment, then you run the risk of an alignment tech, trying to roate the toe bolt 360 degrees and with the slot not being elongated the opposite direction you CAN NOT turn it 360, he has to go all the way back around......
I have seen it!!!!
-J
Old 04-19-2006, 10:44 AM
dirtroad
dirtroad's Avatar
perfect, i'm installing mine tonight - thanks.
Old 04-19-2006, 10:46 AM
Nano
Nano's Avatar
awesome!
thanks thanks thanks
Old 04-19-2006, 11:10 AM
BriGuyMax
Turbo Whore
BriGuyMax's Avatar
Thanks man...this is exactly what I needed...
Old 04-19-2006, 11:13 AM
MIAPLAYA
MIAPLAYA's Avatar
Thank protocav he did all the work. I just used a keyboard effectively
Old 04-19-2006, 11:18 AM
sbcbaseball
sbcbaseball's Avatar
Great write up Chad!
Old 04-19-2006, 12:50 PM
35oZephyR
35oZephyR's Avatar
I used this illustration packet awhile back. Very helpful.
Old 04-21-2006, 10:17 AM
Gary King
Gary King's Avatar
I have a pair of these from Eibach, which are made by SPC, in-stock if anybody needs them. $49.00 shipped to the lower 48 US States.
Old 04-25-2006, 11:48 AM
Super Avan Z33
Super Avan Z33's Avatar
Anyone know where we could get the Dremel cutting tool to make the slot hole bigger?
Old 04-25-2006, 12:40 PM
BriGuyMax
Turbo Whore
BriGuyMax's Avatar
Home Depot or Lowe's
Old 04-25-2006, 03:19 PM
Gary King
Gary King's Avatar
Sears is a good place too.
Old 04-25-2006, 04:02 PM
JDMFairlady21
JDMFairlady21's Avatar
nice.
Old 04-25-2006, 05:47 PM
Super Avan Z33
someone said the 04 up Z's toe bolt slot is already big enough to fit the SPC toe bolt in, has anyone done install the SPC toe bolt by themselves?
Old 04-25-2006, 09:01 PM
MIAPLAYA
MIAPLAYA's Avatar
I have an 04 Z and the slot was not long enough..I'm sure protocav could clarify as he has done this install dozens of times..
Old 04-27-2006, 07:21 PM
BriGuyMax
Turbo Whore
BriGuyMax's Avatar
Just did the install...took me about 2.5 hours because I like to take long beer breaks Not too bad overall. I did have to unbolt my rear sway bar to get the bolts for the factory arms out, and my borla TD exhaust kind of got in the way as far as dremmeling out the holes from the backside went. Other than that...it was a snap. Alignment tomorrow, and then I'll give my impressions.
Old 04-27-2006, 09:16 PM
MIAPLAYA
MIAPLAYA's Avatar
Sweet...congrats!! Let us know how the alignment goes.
Old 05-01-2006, 06:48 PM
sokudo9l6
sokudo9l6's Avatar
i want to get this kit to bring my rear camber back into specs but is it necessary to install the toe bolt also? I had my alignment done and the rear toe is in specs. The rear camber however is at -2.5deg. if it matters...this is lowered on tein basics. The rear is dropped to it's max(1.1 inch).
Old 05-01-2006, 08:17 PM
MIAPLAYA
MIAPLAYA's Avatar
When you alter the camber you are going to throw the toe out. You're better off getting them both...
Old 05-11-2006, 06:40 AM
MySunset350Z
MySunset350Z's Avatar
im new to the alignment stuff. this bolt is all we need to align the car?
im curious because after my 19's and 1.5 inch drop, the stock camber/toe's were bottomed out during alignment and i still wasnt back to spec. my stock ones bottomed out at -2.5 and i need to be at -2.1
Old 05-11-2006, 06:47 AM
BriGuyMax
Turbo Whore
BriGuyMax's Avatar
You'll need the bolts AND the arms to get back in to spec. It's sold as a kit.
Quick Reply: SPC Toe Bolt install write up with pics courtesy of Protocav.
