Does the Z E-Brake grab the F or R
Old Mar 4, 2005 | 07:37 PM
seewinnerslist's Avatar
seewinnerslist
Default Does the Z E-Brake grab the F or R
Does the e-brake grab the front or rear tires?
Is there a way to tighten it for drift purposes?
Also, due to recient(power over) drifting, I am now in need of a driver seat with the air bags in it, so if you have one for sale, let me know.
Old Mar 4, 2005 | 07:45 PM
BigMoeTaki42's Avatar
BigMoeTaki42
The e-brake grabs the rears.
Old Mar 4, 2005 | 11:15 PM
Armitage's Avatar
Armitage
If I am not mistaken, ALL e-brakes grab the rear.
Old Mar 4, 2005 | 11:22 PM
NorCal350's Avatar
NorCal350
WEll I was under the impression that all e brakes grabed front right and rear right only, not both back or both front
or left depending on the car
Old Mar 5, 2005 | 05:44 AM
manofsteele2003's Avatar
manofsteele2003
If you get a chance to look under the car you'll notice that one brake cable go to each of the rear brake assemblies from the handbrake.
The only cars that I know of that had the parking brake in the front are Saabs that were built in the 80's. They had the parking brake mechanisms incorporated into the front calipers. First time I've ever seen that, really wierd.
Old Mar 5, 2005 | 09:16 AM
Destiny350Z's Avatar
Destiny350Z
The e brake grabs the rear ...I should know I was driving with it on....the rear was shaking really bad!!
Old Mar 5, 2005 | 09:50 AM
jlvvega's Avatar
jlvvega
Exclamation
my car e brake get stuck on the rear wheels at times on the mornings. After I apply some pressure with the engine there is a crack from the rear when is released.
Is there a TSB for this problem?
Old Mar 5, 2005 | 10:21 AM
seewinnerslist
All this is, is a build up or rust on the calipers that makes the break pads stick to the rotor. As you drive, the heat and pressure from the breaks will take the rust right off. I sell new cars and they all do the same. The only way that I know to prevent this is to not leave you ebrake on over night.
Old Mar 5, 2005 | 10:41 AM
manofsteele2003
Actually the Z has drums brakes in the rear underneath the rotor for the parking brake. The parking brake is not incorporated into the rear calipers. But just the same, it's just the rear shoes sticking to the inside of the drum due to moisture, nothing to worry about.
Old Mar 5, 2005 | 10:43 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
The E-Brake is only in the REAR and BOTH rear's have the drum style E-Brake...
And ill tell ya... They arent that good! HAHAH
Atleast on mine...
Vigman
Nov 17, 2015 04:34 AM
waldo36
Sep 20, 2015 09:13 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Cyase
Drift
May 31, 2003 02:45 PM
