oversteer in BestMotoring video
Old Nov 27, 2002 | 05:36 PM
pacco's Avatar
pacco
Default oversteer in BestMotoring video
Just wondering for those who have seent he Best Motoring video, in the opening scene a Silverstone looks like it's experiencing oversteer? In mid turn the front wheels are pointing left in a righthand turn??
Cheers,
Ed.
Old Nov 28, 2002 | 05:18 AM
pacco's Avatar
pacco
Clarification: Sorry I meant the Free QuickTime Preview, it looks like significant oversteer to me which Im curious about due to the well know understeer the Z has, it looks fast!
Z rides for the willing, then Gobble, Gobble, SnooZe
Ed
Old Nov 28, 2002 | 05:54 AM
EDogg811's Avatar
EDogg811
usually, when a car has a "tendancy" for oversteer/understeer, this basically refers to which end of the car loses traction first when the vehicle is under acceleration around a moderate speed curve. but under spirited driving or racing conditions, changes in driver's input (either intended or otherwise) can cause a car to behave differently from its "tendancy." with the right driver input, even a fwd vehicle (which is notorious for understeer) can be induced to oversteer under certain conditions. also, keep in mind that a car's handling characteristics are different around low speed curves versus high speed ones. this is mainly due to the difference in transmission gear ratios and the rate of acceleration as a result of it. i have not seen the video, but since a stock 350z is tuned for slight understeer out of the box (pretty much for layperson safety), i'm guessing either the driver in the video entered the corner too fast and had to ease off the throttle mid-corner to compensate (which induces oversteer), or he over-applied throttle through a slow speed corner (which also induces oversteer). of course there are other possible senario. these are just two examples.
Old Nov 28, 2002 | 06:53 AM
phreezee's Avatar
phreezee
The DVD should be in next week!
Old Nov 28, 2002 | 10:06 AM
digerydingo's Avatar
digerydingo
The man was drifting.
Old Nov 28, 2002 | 08:36 PM
z350z's Avatar
z350z
Charter Member #13
Right -- despite the Z's tendency to understeer in a steady-state corner (e.g. when you're testing whether it understeers, oversteers or is neutral), it's sure easy enough to get as much oversteer as you want out of it. Just wind to 6000 RPM and use the throttle!
Old Nov 28, 2002 | 09:22 PM
^Tyr's Avatar
^Tyr
they use differnt driving techniques than you are probably used to. those best motoring vids are famous for their drifting. Its all about technique and driver skill level..
there are lots of resources out there if you'd like to learn more about technique and such..
also look into gymastika (sp?) its the japanese version of an autox but the difference is that they use fewer cones and the track will pass the same areas many times. and people are rated upon drifting techniques and being sideways is the norm
Old Nov 28, 2002 | 09:50 PM
raceboy's Avatar
raceboy
I could be wrong but I think it's actually called gymkanna.
Old Nov 29, 2002 | 09:52 AM
^Tyr's Avatar
^Tyr
your probably right.. i couldnt remember it and i tried looking for it with no luck
Old Nov 29, 2002 | 11:12 AM
S2kRob's Avatar
S2kRob
So when you punch the stability button off, then you can do what you want? Or does it still cut in at some point?
Old Nov 29, 2002 | 11:42 AM
^Tyr's Avatar
^Tyr
from what i understand when you turn it off, its off completely off, not some life of its own thing with self preservation that'll kick in and eliminate the driver to save itself
StreetStandard
Videos
Feb 4, 2016 09:44 AM
Justin100
Nov 29, 2015 03:58 PM
Mw870
Oct 2, 2015 08:23 AM
carid
Misc.
Sep 10, 2015 06:16 AM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
