Low 13 or High 12sec. Combo
Old Jun 10, 2005 | 01:24 PM
qwk350z's Avatar
qwk350z
Default Low 13 or High 12sec. Combo
I'm new here and to the whole import thing. I'v had a 2000 WS6 TransAm and several mustangs. What does it take to get the 350z to run low 13's or high 12's? I have a 03 Touring edition 6-speed. Only thing I'v done so far is tint the windows. I want to keep it a bolt on car. I'v read on here that pulleys seem to be a good mod. What about a cold air kit or exhaust?
Thanks for any help.
Old Jun 10, 2005 | 01:52 PM
rikee's Avatar
rikee
Slick tires my friend, best way to lower your time on 1/4 mile.
Old Jun 10, 2005 | 03:19 PM
Mantis3024's Avatar
Mantis3024
almost every bolt on, ecu reflash, slicks, and a good driver
Old Jun 10, 2005 | 05:31 PM
Nitrouz's Avatar
Nitrouz
Back to Z
Fi.
Old Jun 10, 2005 | 06:48 PM
Damian's Avatar
Damian
Originally Posted by nitrouz
Fi.
Thats one hell of a bolt on, hehe.
Old Jun 10, 2005 | 07:01 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
It is NOTHING like getting a Mustang to low 13s/high 12s. I'm a Mustang fan as well and know where you are coming from.
Check out alberto's thread though, he's in low 13's and will soon get into the 12's and doesn't have a whole lot of mods. https://my350z.com/forum/drag/117139-13-1-107-all-motor.html
I've got a few recommendations that you may want to know about if you want me to PM you a list.
Old Jun 11, 2005 | 04:42 AM
Zivman's Avatar
Zivman
FI 100% -
Don't even mess with N/A - been there done that
Old Jun 11, 2005 | 05:31 AM
NA&CH's Avatar
NA&CH
Well most of us cant afford FI(me included )
Old Jun 11, 2005 | 07:00 AM
ActionJackson's Avatar
ActionJackson
If you can't afford FI... then forget about even getting into 12s, you'll never touch that number in NA motors without a budget that could make you afford FI. Not only that, after you've built your NA engine you'll wind up with 330 rwhp at most, while with the same money spent you probably could've gotten 500+ on a FI setup.
Old Jun 11, 2005 | 08:56 AM
Jaki's Avatar
Jaki
Originally Posted by Zivman
FI 100% -
+1
If you can't afford FI right now, then just save up, its worth it. I first started out NA and realized that I spent almost as much money on NA mods as an FI kit costs, and I only gained a fraction of the power that FI gives. I then stopped spending money on NA mods, and just saved up for FI for a while, and now I'm FI.
If you want to stay NA though, I'd say get pulleys, good tires, headers, test pipes, flywheel, exhaust, intake (doesn't really give u much power, but its cheap, so why not), ecu reflash, and may be a short shifter (its cheap and it should help you a little, but the stock shifter already has a pretty short throw...), and you gotta drive really good. That should get you to ur goal.
Old Jun 11, 2005 | 09:49 AM
zillinois's Avatar
zillinois
3.9 final drive ($1350 installed)
tilton flywheel ($1300 installed)
drag radials ($600)
For about 3 grand, you can get low 13's. I ran the above setup without the d.r.'s and got a 13.3. High 12's are possible with the same setup with slicks.
Old Jun 11, 2005 | 10:35 AM
VeeTec's Avatar
VeeTec
DR's, pop charger, exhaust, high flow cats, techno square ecu is the route I am starting off with.
I will be staying n/a.
I figure if I can run 13.6 stock, these mods should get me to a very low 13 at least, and maybe a high 12.
I could have run a 13.5 stock, if my traps were up where they normally were, but knock retard from the gas affected it a little.
A 106-107 mph trap should be enough to see high 12's with good traction.
I am keeping the car stock a little longer though, as I want to beat my best stock time, shooting for a 13.4-13.5.
The car seems to be getting stronger with higher miles, as I am at 19K now.
Old Jun 11, 2005 | 11:59 AM
Brandon@Forged
I tried to send you that PM but I got this message:
Turbogt has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
Old Jun 11, 2005 | 12:02 PM
Brandon@Forged
I'm actually agreeing with everyone, the list I put together enters Turbonetics ST and S/C prices at the cheapest. If you go with the most expensive parts you could have a GReddy kit with everything you need for it. Not to mention potential, you're not going to see 420+rwhp in N/A form on the 350Z.
350Z_Al
Oct 29, 2020 07:44 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
