Bad night
Old Dec 7, 2005 | 09:24 PM
RobertH's Avatar
RobertH
Default Bad night
i was at the track an my car was running good. well i wanted to go one more pass so i did my burnout an pulled up to the line. i revved to about 2500 an when the light turned green i dumped the clutch. well my car make a loud clankin noise an didnt move so i turned it off an back on for no reason an it still didnt move. i think the clutch went out but the bad thing is i just had the clutch flywheel an tranny replaced 8000 miles ago.
Old Dec 7, 2005 | 09:51 PM
overZealous1's Avatar
overZealous1
sounds like an axle or c.v. broke
Old Dec 8, 2005 | 04:17 AM
BigMike's Avatar
BigMike
Sorry to hear about that. But you have to wonder if the problems (clutch, etc.) are due to the way you're treating the car. The Z was not built for drag racing and hole shots. I think the drive-train is too fragile to bang on it like that over and over. You can probably expect the same results each 8k miles if you continue.
Jack the rear of the car up. If the drive shaft spins when the car is in gear, its the rear end or CV. If the drive shaft isn't moving, its the clutch or tranny.
Are you still under warranty?
Old Dec 8, 2005 | 04:36 AM
Very unusual. I have more than 100 time slips, and my car runs fine (knock on wood).
Old Dec 8, 2005 | 08:36 AM
RobertH's Avatar
RobertH
yes its still under warranty but after i let it sit for bout 30 min. i got in it an when i let out the clutch it made a little grinding noise an moved less than 1 mph. an when i hit the gas it stopped when i put it in reverse an did the same thing it barely moved again but when i hit the gas the grinding noise got louder
Old Dec 8, 2005 | 10:21 AM
EynonPower's Avatar
EynonPower
When you did it, did it smell really really bad? Not as in burning rubber though?
Old Dec 8, 2005 | 02:54 PM
RobertH's Avatar
RobertH
nissan said i shattered my clutch
Old Dec 8, 2005 | 03:00 PM
JDMFairlady21's Avatar
JDMFairlady21
damn thats crazy... how many miles do you have on the car? and how often do you race it?
blasian's Avatar
blasian
That sucked man. I saw when it happened but didn't hear it though. Depressing to see a Z go down like that.
Old Dec 8, 2005 | 03:11 PM
HighwaySpeed's Avatar
HighwaySpeed
Wink
Originally Posted by BigMike
The Z was not built for drag racing and hole shots. Are you still under warranty?
The Nissan warranty covers racing breakdowns???
Old Dec 8, 2005 | 09:03 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
he wasnt at the track
my diff cover shattered on me at the track... my differential pumpkin dropped down...
Old Dec 8, 2005 | 09:04 PM
JETPILOT's Avatar
JETPILOT
Time for a high performance clutch.... ATS Triple carbon.
Respect
JET
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
