Storing car for 6 months
Old Jan 11, 2006 | 01:59 AM
bcsaga's Avatar
bcsaga
Default Storing car for 6 months
I'm taking a break from school b/c of my health problems, so I have no choice but to leave my car here and head back to Korea for a full semester (about six month including summer break) I did my search, and found out most of the important stuff. However, I just wanted to confirm. Better safe than sorry, right?
Since I rent, I don't have a garage. My dear Z will be stored in a commercial storage place (not specifically for cars) with concrete floor with no heated, no a/c, nothing.
1. Car cover with some sort of cloth underneath to guard the paint.
2. Battery Maintainer.
3. Tire pressure up to about 40 psi or removal of the wheels and putting on 4 jackstands.
4. Park the car on top of tarp to avoid moisture.
5. Full tank of gas with fresh engine oil before and after storing. (No additives like stabilizer to the tank according to Nissan.)
6. Take out floormats and open the windows a tad. (Maybe add some sort of odor absorber)
I think these are the most important stuff. Any further inputs confirming or adding info will be greatly appreciated. Thanks
Old Jan 11, 2006 | 02:03 AM
zand02max's Avatar
zand02max
If you don't have a plug in just remove the battery. Also ensure you do a complete detail prior to storing it.
I myself am going to Korea but for a year, so my ZR will be stored and not driven or started for 1 whole year, I feel your pain man!
Old Jan 11, 2006 | 02:14 AM
bcsaga's Avatar
bcsaga
Remove the battery as in disconnect the negative terminal? or completely take off the battery outta the car?
I will be detailing the car in 30 degree weather. Lucky me
Where in Korea will you be? I was surprised to see that Z's are more exotic than 360 Modena in Korea Last week, when I was in Korea, a black ZR was in a Chungdam showroom with Ferrari Testarossa, Lambo Diablo, Aston Martin DB9. It felt good to have Z in the same showroom as those cars I wish I can bring my car over to Korea.
Old Jan 11, 2006 | 02:59 AM
zand02max's Avatar
zand02max
I would completely take it out, as it will be dead when you come back. Store it in your house and not on the ground or concrete as this will drain it.
I am going to Seoul!
Old Jan 11, 2006 | 05:15 AM
spacemn_spiff's Avatar
spacemn_spiff
+1 on putting the Z on jackstands and leave the wheels/tires unloaded. Modern tires have ozone fighting compound that is activated when the tire flexes or in other words ridden on, if the tire is loaded with no riding cracks may develop because of ozone.
And I would put minimal gas in the tank, so when you are back to drive your Z you can get a fresh tank full.
+1 on Oil change and drive it 100 miles or so after the oil change.
Old Jan 11, 2006 | 07:14 AM
2003 Perf. Z's Avatar
2003 Perf. Z
my $.02 having done this 20 times...
1. Car cover with some sort of cloth underneath to guard the paint. Good.
2. Battery Maintainer. Take it out completely and leave it somewhere warm.
3. Tire pressure up to about 40 psi or removal of the wheels and putting on 4 jackstands. If you can remove the wheels, that would be best. I have left a car for 6 months on it's tires, overinflated and they were fine when I went back to get it.
4. Park the car on top of tarp to avoid moisture. Good, or some cheap carpet (Astroturf, etc.)
5. Full tank of gas with fresh engine oil before and after storing. (No additives like stabilizer to the tank according to Nissan.) No - half tank, and add some Stabil and a can of dry gas. One half tank of this 'crap' will not hurt anything, and will save you starting problems when you return.
6. Take out floormats and open the windows a tad. (Maybe add some sort of odor absorber) Leave them closed! - if there's a fire in another unit (this has happened to me) you will end up with soot, and insects in your car.
7. Mousetraps if necessary so they don't get into the engine compartment and eat your firewall insulation.
Old Jan 11, 2006 | 07:21 AM
spacemn_spiff
Originally Posted by rich150001
Im not really sure but wouldn't having low gas be bad for it. I read somewhere that keeping the gas low in a car will produce condensation, thus over time it can be bad for the car.
I stand corrected. Thanks for the explaination.
Old Jan 11, 2006 | 09:47 AM
Badger Z's Avatar
Badger Z
Default Try this...
I bought these to absorb moisture in the interior while parked over winter.
http://eastwood.com/shopping/product...rd=zone+absorb
ZoneDry moisture absorbers. I'd rather keep the windows up while stored. This is the first time I've tried them so I can't say how effective they are yet.
Two more things - 1) buy some pantyhose and cut the legs off. Slip them over the ends of the exhaust tailpipes. Will allow moisture/humdity escape but not let bugs and junk get inside.
2) Use some blocks or wheel chocks to block the tires from rolling and leave the parking brake off. No need to keep that system under stress for that long if you're on a level surface and can block the wheels.
Old Jan 11, 2006 | 11:43 AM
ohw's Avatar
ohw
If you decide to pull the battery, make sure you follow the procedure for the Z, because of the auto lower window. It's in the owner's manual. I would lower the window a bit, such that it is not a tight seal, but not wide enough for insects to get in. I see some good suggestions here about mouse traps and pantyhose over exhaust tips.
Have stored my cars for winter for the last 15 years, winter is 4 to 5 months here in Canada. I do everything you listed from 1-6. Few notes:
- I fill the tank to avoid condensation, with no additives every time, no problem so far.
- I hang a sheet of dryer fabic softener as odor absorber.
- Tires stay on the car w/ 40 PSI with no problem, have not used jack stands
Old Jan 11, 2006 | 02:05 PM
nickintempe's Avatar
nickintempe
Is the idea of having a friend fire it up and maybe take it around the block every once in a while out of the question?
Old Jan 11, 2006 | 02:10 PM
Lemans350's Avatar
Lemans350
You wouldnt want to do that when there is snow and salt on the ground, defeats the whole purpose of storing
Old Jan 11, 2006 | 02:18 PM
bcsaga's Avatar
bcsaga
Thanks everyone for help.
Pantyhose around exhaust tips I should take pics after I put them on my car
etkms
Jun 19, 2022 06:30 PM
lolwatbro
Oct 9, 2021 04:58 AM
Vigman
Nov 17, 2015 04:34 AM
davidm350
Oct 31, 2015 02:28 PM
RyansZ33
Sep 15, 2015 05:54 AM
