idleing at 500 RPM! SON OF A *****!
Old Feb 2, 2006 | 07:00 PM
eat rice z33's Avatar
eat rice z33
Default idleing at 500 RPM! SON OF A *****!
ok well, i was driving my baby around today, and realized i was havign little more difficulty coming off of lights than usuall( i dont use throttle only clutch modulaton) i then noticed the car was slightly rougher idling, i looked at the tach and sure enough she was at 500 rpm idle! Wa can cause this? my only mod would be cusco catch can, on the left valve cover.
Old Feb 2, 2006 | 07:09 PM
jinsei888's Avatar
jinsei888
wait, why do you even have that mod to begin with? lol
ok back on topic, was your A/C off? The Z has a tendency to drop RPM when the A/C is off, I think there is a fix for it...i dunno haha
Old Feb 2, 2006 | 07:17 PM
MustGoFastR's Avatar
MustGoFastR
vacuum leak due to catch can instal?
Old Feb 2, 2006 | 07:52 PM
eat rice z33
ac was off, and nah its not the catch can, PS oive been using catch canes on myu buddies car for years and its no secret that that on the NA cars it catches blow by oil
Old Feb 2, 2006 | 08:17 PM
jakesford's Avatar
jakesford
sounds like a vacume leak for sure, with the AC on the motor should actually be running at a higher rpm, the computer request a higher rpm with AC to keep the compressor from affecting the engine
Old Feb 2, 2006 | 10:06 PM
FireStormTT's Avatar
FireStormTT
I think mine has always idled around 5-600, what does a normal car idle at?
Old Feb 2, 2006 | 10:55 PM
ZZ33bOI's Avatar
ZZ33bOI
mine idle at 800-1000
Old Feb 2, 2006 | 11:09 PM
Z_Driver's Avatar
Z_Driver
Master
Idle S/B 650rpm +/- 50rpm in Neutral for a manual transmission.
Or
Idle S/B 650rpm +/- 50rpm in Neutral or Park for the automatic transmission.
Mine idled at 800rpm until I installed the iridium plugs and checked the gap. After that my car idled correctly with a smoother idle and no misses. It also picked up about 1.5mpg on the freeway as well.
Old Feb 3, 2006 | 05:00 AM
Category5's Avatar
Category5
I too thought mine was low @ 700rpm with A/C off, but apparently it's normal (500 seems a little too low). It does feel a little rough-idle at times. Unfortunately because of the drive-by-wire design, there's no way to adjust it. My old Z had an idle-screw you could +/- 100 rpms...those were the days.
Old Feb 3, 2006 | 05:59 AM
PoWeRtRiP's Avatar
PoWeRtRiP
well is it stalling out? if not who cares.
Old Feb 3, 2006 | 06:03 AM
Silkk's Avatar
Silkk
Mine idles between somewhere between 650-850...
Old Feb 3, 2006 | 10:32 AM
eat rice z33
yeah you gto a point, its not stalling out, so meh wtvr ill learn to drive with it! thats the beuty of a human being! we adapt
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Justin100
Nov 29, 2015 03:58 PM
