Tire Pressure Light
so if you swap your factory 17's for aftermarket 18's you can reuse your stem and the tps would work? someone please answer this ? i have searched for a while and cant get a good answer.
Join the conversation.
https://my350z.com/forum/wheels-and-tires/169615-tire-pressure-sensor-tps-q-s.html
This seems to have been discussed many times before but with no real answers. Hopefully someone will chime in with some helpful info...
You can resuse the TPSM that are in the valve stem only if the rim your changing to will support the stem. Volks for example will not work. Just get some nice rims and forget about it. Light comes on only after driving on a long trip. Check your pressure manualy every so often and enjoy the Z.
