Is something wrong with my tranny?
Old Apr 8, 2006 | 06:36 PM
d_le's Avatar
d_le
Default Is something wrong with my tranny?
I have a 2004.5 Enthusiast Roadster, with traction control but no VDC. Driving in a straight line and down-shifting usually doesn't produce any problems. But several times, when I take a turn, I have the clutch engaged and pop into 2nd or 3rd (mostly 3rd gear) at about 20 mph, the "slip" light flashes and it seems like there's no power to the wheels. Am I experiencing the infamous 2nd/3rd gear transmission problems common with the 03 and early 04's?
Does anyone else experience this? Is it just my driving technique?
Old Apr 8, 2006 | 06:40 PM
Johnny225's Avatar
Johnny225
Are you rev-matching when downshifting? Does the car jerk backwards when you downshift? If so, then yes, the traction control would kick in during a corner. That's normal. Downshifting like that however, is very bad for the car and tranny.
Old Apr 8, 2006 | 06:54 PM
ZPatrick's Avatar
ZPatrick
turn off the traction control
Old Apr 8, 2006 | 09:14 PM
Hella's Avatar
Hella
this sounds like more of a diver problem than a tranny problem.
Old Apr 8, 2006 | 10:32 PM
One, it is very unusual to shift while in a curve. A very long curve yes. Not that that would cause SLIP.
When accelerating in a corner (curve), the rear tires are subject to irregularities in the roadway: dips, cracks, drainage joints. Those small surface faults will activate SLIP momentarily.
Old Apr 10, 2006 | 06:55 AM
maxpowers's Avatar
maxpowers
+1 on that comment, thats an easy way to lose your rear end. My slip light turns on sometimes when I'm in a corner if I hit a bump in the road.
Old Apr 10, 2006 | 07:00 AM
NeoRacer_106's Avatar
NeoRacer_106
You did'nt pay him enough:P
Old Apr 10, 2006 | 03:03 PM
bamyi's Avatar
bamyi
Its not the tranny problem. Like the comments above, try NOT shifting through a curve and see what happens.
The infamous tranny problem is when your gears acutally grinds when you shift.
Obadabot
Jun 18, 2023 11:31 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
