300Hp
Old Apr 27, 2006 | 06:11 AM
ericbel88's Avatar
ericbel88
Default 300Hp
how did the 06+ z's achieve the 300 hp stock now? what changes did they make to the motor?...also i heard that they have some tourque loss from the previous years, is the performance the same with more horse and less torque?
thanks
Old Apr 27, 2006 | 06:13 AM
SS728's Avatar
SS728
The 06 Base model is the only one without the 300, it has like, 270ish or something.
The 300hps have 260ft/lbs.
As for the mods to get it 300, I dont have a clue.
Old Apr 27, 2006 | 06:14 AM
amsweigart@hotm's Avatar
amsweigart@hotm
I think the 06's have a slightly different cam which makes the red line a bit higher. NOTE: I think
Old Apr 27, 2006 | 06:16 AM
amsweigart@hotm
My 06 Base has the 300 hp rev-up engine...it's a 6 speed tho
Old Apr 27, 2006 | 06:25 AM
ChazzReinhold's Avatar
ChazzReinhold
i have an 06 base model and i have 300 hp not 270.
Old Apr 27, 2006 | 06:42 AM
TreeZ's Avatar
TreeZ
don't short change us '06 base modelers. i have 3 hundo too.
Old Apr 27, 2006 | 06:48 AM
ChazzReinhold
Old Apr 27, 2006 | 07:05 AM
boyan2795's Avatar
boyan2795
I think I read it on the actual nissan usa web page, the only changes they made was to the exhaust. The new models sound different because of it, and they have 300hp. The engine, and everything else is the same x ept for some small external things.
Old Apr 27, 2006 | 07:20 AM
zedated's Avatar
zedated
I dunno exactly, but from what I've read, the rev-up engines have a different lower intake plenum, maybe different cam, dual-port exhaust, and higher redline. Can anyone confirm this?
Old Apr 27, 2006 | 07:25 AM
sq40's Avatar
sq40
This has been beat to death on here, do a quick search on the Revvup Motor.
Old Apr 27, 2006 | 07:26 AM
jenna350z's Avatar
jenna350z
Yea thats what i heard it was from a friend thats a tech a nissan.
Old Apr 27, 2006 | 07:33 AM
KingOfV6's Avatar
KingOfV6
yes nissan really hooked up the 06 base with 300hp, even HID's outbattling the 05 base, GO NISSAN!!
Old Apr 27, 2006 | 07:53 AM
Armitage's Avatar
Armitage
This is basically the only useful post in this thread.
I can confirm the newer lower-intake plenum, variable-valve timing on the both the intake and exhaust cam, forged internals, and a higher redline.
Old Apr 27, 2006 | 08:14 AM
ANXIOUZ's Avatar
ANXIOUZ
^^^ Yeah, I haven't seen this much disinformation in a single post in quite a while.
And for the record:
Original engine: 287HP / 274TQ
Rev-up engine: 300HP / 260TQ
Old Apr 27, 2006 | 08:17 AM
mc4life's Avatar
mc4life
the ATs are still 287...
Old Apr 27, 2006 | 08:30 AM
allen@v2-tech's Avatar
allen@v2-tech
I've never owned a 350 before. But considering how the direction the import tuner market is headed, my best guess is that the timing on the car has been changed. This is apparent when the HP numbers have increased but the torque figures have stayed relatively the same, which looks to be the case here. The timing has probably been advanced by 1-1.5 degrees with different cam shafts to compensate for the increased timing.
This would explain why the models prior to the 06s feel more torqy.
Can anyone confirm the numbers? 06 HP and Torque v. Pre 06 Hp and TQ?
Cheers
Allen
Old Apr 27, 2006 | 09:16 AM
roast's Avatar
roast
The previous models have 14 more ft-lbs of torque, but the newer models have 13 more hp. I have an '04 base model and yeah maxims numbers are right for both years... mine is 287hp:274tq.... I would take HP over TQ any day. Luckily I have one of the lighter models so my lbs:hp ratio is still better than any of the '06's with 300hp.
Old Apr 27, 2006 | 09:24 AM
HDPDZO6's Avatar
HDPDZO6
Used to own a Honda?
Old Apr 28, 2006 | 07:52 AM
Armitage's Avatar
Armitage
Peak numbers mean poop. Area under the power curve is all that matters.
Old Apr 28, 2006 | 10:43 AM
SH82N-Z's Avatar
SH82N-Z
Going from 287 to 300 is always doable with small chips. Just like the BMW E46 325 AND 330. The additioanl gain on the 330 is due to a small chip inside the engine. Same engine and same everythinggggggggggg. Just a little chip!!
